So im trying to setup Mongodb on Ubuntu 16.04 but im running into trouble.
when running :
sudo systemctl status mongodb
I get the following:
mongodb.service - High-performance, schema-free document-oriented database
Loaded: loaded (/etc/systemd/system/mongodb.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2016-09-10 14:02:22 CEST; 14s ago
Docs: https://docs.mongodb.org/manual
Process: 8724 ExecStart=/usr/bin/mongod --quiet --config /etc/mongod.conf (code=exited, status=14)
Main PID: 8724 (code=exited, status=14)
According to the mongo-docs, status=14 is:
"Returned by MongoDB applications which encounter an unrecoverable error, an uncaught exception or uncaught signal. The system exits without performing a clean shut down."
I doesnt really point me in any particular direction.
My /etc/systemd/system/mongodb.service looks like this:
[Unit]
Description=High-performance, schema-free document-oriented database
After=network.target
[Service]
User=mongodb
[Install]
WantedBy=multi-user.target
Any thought on what may be the cause of this?
Thank you
