I was running few commands and suddenly my apt-get command stopped working, reporting command not found error.
Kindly help. I am blocked due to this.
I tried commands from this answer - askubuntu question for unmet dependencies
"Command not found" is the common response for a command you're not authorized to use. In this case, apt-get is a system command, and requires root privilege; you should type sudo apt-get and whatever you're trying to install, remove, etc. You'll be prompted for your user password, and assuming your'e on the sudoers list, the command will then execute with root privilege.
