Host OS: Mac OS X Lion Guest OS: Ubuntu 11.10 Virtualization: Vmware Fusion
I am the type of person that relies heavily on shortcuts. The fact that I don't have "Super" key on my Mac keyboard really bothers me. At first, I thought the apple/command key would be mapped to the "Super" key in Ubuntu by default, but it didn't work like that. How can I make "Super" key available to my setup? Thanks.
Below are shortcuts that involved the "Super" key. I have labelled the ones that didn't work for me.
Launcher
  • Hold Super - Invoke the Launcher.
  • Hold Super, then 1 or 2 or 3 and so on until 0 - Open or focus an application. The number corresponds to the location of the icon on the launcher from top to bottom.
    • Adding Shift will open a new instance of the application if it's already open.
    • Holding the key is also useful when you want to get to the Launcher but do not want to invoke the Dash.
  • Super-T - Open the rubbish bin/trash can.
Dash
  • Tap Super - Opens the Dash. The open signal is sent when you let go of the key, not when you push it down, so if it feels slow just let go of the key earlier.
  • (not working)Tab - 11.10+ only - Move to the next lens (When the dash is open)
  • (not working)Shift-Tab - 11.10+ only - Move to the previous lens (when the dash is open)
  • (not working)Super - A Open Applications lens
  • (not working)Super - F - Open Files & Folders lens
  • (not working)Super - M (11.10+ only) - Open the music lens
Window Management
  • (not working)Super - W - Spread mode, zoom out on all windows in all workspaces.
  • (not working)Super - D - Minimize all windows; hitting it again restores them.
Workspace Management
  • (not working)Super - S - Expo mode (for everything), zooms out on all the workspaces and lets you manage windows.
In my case, all I had to do is disable the key mappings from fusion (i use the touchpad to swipe at osx level - no need for super-tab)
Daniel
If you Ubuntu will interpret the Windows/Start Menu key as the Super key then you can map it from the Keyboard & Mouse dialog in Fusion. From the VMware Fusion menu, select Preferences then go to the Keyboard & Mouse tab. From there you can add and delete keyboard mappings.
If the problem is that Ubuntu isn't interpreting the Windows key correctly, you should use the xmodmap command in a X startup file. For a complete tutorial try this link
kbyrd
  • 163
