I added Bazel distribution URI as a package source using the following instructions from their website:
$ echo "deb [arch=amd64] http://storage.googleapis.com/bazel-apt stable jdk1.8" | sudo tee /etc/apt/sources.list.d/bazel.list
$ curl https://storage.googleapis.com/bazel-apt/doc/apt-key.pub.gpg | sudo apt-key add -
$ sudo apt-get update && sudo apt-get install bazel
$ sudo apt-get upgrade bazel
Installation went fine, but I keep getting these annoying messages from apt-get whenever I update or install a new package:
N: Ignoring file 'bazel.lis' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
So I decided to uninstall bazel and install it through the ubuntu installer, however this did not get rid of the apt-get message since the distribution URI is still in the list although the package is uninstalled.
How can I remove it from the list? From the question How can PPAs be removed? it seems like the following might work, but before doing it I wanted to make sure I'm not removing ppas for other packages.
sudo add-apt-repository --remove ppa:http://storage.googleapis.com/bazel-apt
Could you let me know if I'm on the right track? Thanks!
