I've create a backup of all the packages I've installed on one ubuntu server and try to restore it to a new ubuntu server.
I did the same as mentioned in the first answer of this question
Issue is after running the last two commands sudo dpkg --set-selections < ~/Package.list& sudo apt-get dselect-upgrade -y, I can't install new packages.
When trying to install pip3, I have this error
Building dependency tree
python3-pip : Depends: python3-setuptools but it is not going to be installed
Recommends: build-essential but it is not going to be installed
Recommends: python3-dev (>= 3.2) but it is not going to be installed
One of the solution I found was to do a sudo dpkg --configure -a
But when running the command, this the trace I have
[my:/home/my]$ sudo dpkg --configure -a
Setting up ppp (2.4.5-5.1ubuntu2.2) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
insserv: Service gdm has to be enabled to start service pppd-dns
insserv: exiting now!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package ppp (--configure):
subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of pppconfig:
pppconfig depends on ppp (>= 2.3.7); however:
Package ppp is not configured yet.
dpkg: error processing package pppconfig (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of pppoeconf:
pppoeconf depends on ppp (>= 2.4.2+20040428-2) | pppoe (>= 3.0); however:
Package pppoe is not installed.
pppoeconf depends on ppp (>= 2.4.1.uus2-4); however:
dpkg: error processing package pppoeconf (--configure):
ppp
pppconfig
pppoeconf
I'm not sure what to do next.
