I have a Lenovo z570 i3, Ive installed the packages available for nvidia and my graphics card is still not recognised?
It displays the following error upon trying to configure it
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file and restart the X server
Any ideas?
Jorge Castro
  • 73,717
Ryan
You laptop has a hybrid card, you have a intel + nvidia card running in your system, the drivers you are installing for you nvidia are not working correctly because they are not being loaded on startup.
You Intel card is running as primary so you have 2 options:
1) If you BIOS allows to turn off the Intel card and leave the nVidia one running then the drivers will work correctly;
2) Use software that enables you to use some functions of your nVidia card, its called Bumblebee and its largelly discussed on use/installation, etc, on the site.
Bruno Pereira
  • 74,715
with the Z570 there is a switch on the front of the laptop flick it and then you can make the Nvidia your primary graphics card in the nvidia settings
Exilexx
Under the 11.04 and laters the default driver for the Nvidia cards are the nouveau but they can't be installed on the same machine with the official nvidia driver, so you have to purge that package before installing the nvidia closed source driver.
sudo apt-get --purge remove xserver-xorg-video-nouveau
after that install the driver trough jockey-gtk ( "Additional drivers" dialog )
gksudo jockey-gtk
After that you can manage your configuration files with the nvidia-settings package, so install it with
sudo apt-get install nvidia-settings
and start the control panel with
gksudo nvidia-settings
this is the right procedure in a nutshell, looking at your report you probably miss the config files so if you do not want to do by hand install and use the nvidia-settings utility.
Micro
  • 2,178
  • 15
