I have a Lenovo Ideapad Z570. Its specs are:
  • Intel Core i5-2410M Processor with Intel Turbo Boost Technology* 2.0(2.30GHz, 3MB Cache) RAM 4GB
  • Hard Disk 750GB
  • Video Graphics Nvidia Geforce GT 520 M Dedicated GPU 1GB
  • Display 15.6’’ Backlit LED HD (1366x768), 16:9 widescreen
  • Multimedia Drive Integrated DVD reader/writer or Blu-ray Disc™1 drive
  • Wireless Yes
  • Bluetooth Yes
  • Webcam Yes
  • Ports 4 x USB2.0 ports (1 combo with eSATA), 5-in-1 card reader(SD/SD pro/MMC/MS pro/XD), RJ-45, VGA, internal analog microphone, 1/8” stereo headphone output & microphone input combo jack, HDMI
So my question to you is, Will I be able to successfully install ubuntu with all of my drivers working or will I have problems? Also which version of ubuntu should i install? Thank You.
Bruno Pereira
  • 74,715
5 Answers5
Your PC is more than enough to run Ubuntu (desktop edition for example).
Here are the Recommended Minimum System Requirements
Ubuntu Desktop Edition
700 MHz processor (about Intel Celeron or better)
512 MiB RAM (system memory)
5 GB of hard-drive space (or USB stick, memory card or external drive but see LiveCD for an alternative approach)
VGA capable of 1024x768 screen resolution
Either a CD/DVD drive or a USB port for the installer media
Internet access is helpful
For Ubuntu version i recommend Ubuntu Desktop Edition
You can download it here
LnxSlck
  • 12,456
Ubuntu should work without any problem, although some there always is a risk that something will need more attention. The best what you can do is to run Live CD and test if it works how it is desired.
About version it also depends what you want to use it for. For example I use 10.04 as it is stable and I have quite a lot of python code in version supported by 10.04. Probably you will not have so specific requirements, but if you have any it would help.
tomasz74
  • 278
Be careful with wireless, you should have no problems with any of the other devices but you may have an issue with wireless support. Its a problem with linux in general, always remember to test out the version you are going to install by clicking try Ubuntu upon booting the liveCD or LiveImage.
I have a Z570 and have been using it for over a year now. The only thing I have been unable to get to work is the webcam. Though it does respond, it shows VERY dark and I have found no way to make it truly usable.
Wifi might take some tweaking to get full N speeds, but overall it worked out of the box for everything else.
yes, your laptop will definately work just fine with Ubuntu. I have found many problems with 64-bit for netflix and DVD playback. I might be the only one with that problem on 13.04 though
