I am getting this sort of error while downloading composer.
php composer-setup.php
All settings correct for using Composer
PHP Warning:  file_put_contents(/home/vasu/.composer/keys.dev.pub): failed to open stream: Permission denied in /home/vasu/composer-setup.php on line 468
PHP Warning:  file_put_contents(/home/vasu/.composer/keys.tags.pub): failed to open stream: Permission denied in /home/vasu/composer-setup.php on line 485
Downloading 1.2.0...
PHP Warning:  openssl_verify(): supplied key param cannot be coerced into a public key in /home/vasu/composer-setup.php on line 576
PHP Warning:  openssl_free_key() expects parameter 1 to be resource, boolean given in /home/vasu/composer-setup.php on line 577
Signature mismatch, could not verify the phar file integrity
karel
  • 122,292
  • 133
  • 301
  • 332
Easy way
Try the easy way first. The hard way was included in this answer because of the error messages mentioned in the comments.
sudo mkdir -p /usr/local/bin
sudo apt-get install curl
curl -sS https://getcomposer.org/installer | php
sudo mv composer.phar /usr/local/bin/composer
In Ubuntu 16.04 and later composer can be installed from the default Ubuntu repositories. Open the terminal and type:
sudo apt install composer
Hard way
First check if /usr/local/bin/ exists, and if not make the /usr/local/bin/ directory.
If /usr/local/bin/ already exists, the above command will do nothing except return this message:
mkdir: cannot create directory ‘/usr/local/bin’: File exists
Run these commands:
sudo chmod -R 755 /usr/local/bin/
cd /usr/local/bin/
ls # list the old composer file(s)
sudo rm <old-composer-files> # delete the old composer file(s)
Then if you type composer in the terminal it will be accessible globally in your system.
karel
  • 122,292
  • 133
  • 301
  • 332
