curl -sS https://getcomposer.org/installer | sudo php -- --install- dir=/usr/local/bin --filename=composer
When I run the above command in terminal I got this this response:
Some settings on your machine make Composer unable to work properly.
Make sure that you fix the issues listed below and run this script again:
The json extension is missing.
Install it or recompile php without --disable-json
The phar extension is missing.
Install it or recompile php without --disable-phar
The iconv OR mbstring extension is required and both are missing.
Install either of them or recompile php without --disable-iconv
