52
I am trying to install Simplicity studio on Ubuntu 15.04 (64-bit) and I get this error
E: Unable to locate package lib32bz2-1.0
E: Couldn't find any package by regex 'lib32bz2-1.0'
I tried to install lib32bz2-1.0 package, again I get the same error. How to install package lib32bz2-1.0 on Ubuntu 15.04(64-bit)
heemayl
  • 93,925
Rao
  • 623
5 Answers5
48
The package (32 bit) you are looking for is libbz2-1.0:i386, its 64 bit version is libbz2-1.0:amd64.
At first enable multi-arch support (if not done already):
sudo dpkg --add-architecture i386
Now run:
sudo apt-get update
You can now install the package by:
sudo apt-get install libbz2-1.0:i386
heemayl
  • 93,925
42
Are you triying to install Android Studio on Ubuntu?
If you say: Yes!!. This answer is for you :-).
Maybe are you triying to install android studio with this tutorial?. It has deprecated dependencies on Ubuntu 16.04.
This command has issues:
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0 lib32stdc++6
After a few searchs on Google I found a possible solution in this post: Bad dependency on install command.
This command specifies the 32 bits version of the extra libraries that you need to setup android studio. It works for me on Ubuntu 16.04:
sudo apt-get install libz1 libncurses5 libbz2-1.0:i386 libstdc++6 libbz2-1.0
Hope it helps :-).
mrroot5
  • 559
37
Try to install it manually by typing:
sudo apt-get update
Update:
if you remove lib32bz2-1.0, it will be installed successfully.
sudo apt-get install lib32z1 lib32ncurses5 lib32stdc++6
Otherwise:
sudo apt-get update
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0 libstdc++6:i386 libfontconfig1:i386 libxext6:i386 libxrender1:i386 libgstreamer-plugins-base0.10-0:i386
Bilal
  • 3,747
This works for me on my Ubuntu 15.04(64-bit)
sudo apt-get install lib32z1 lib32ncurses5 libbz2-1.0:i386 lib32stdc++6
Clock ZHONG
  • 1,015
  • 13
  • 17
sudo apt-get install libz1 libncurses5 libbz2-1.0 libstdc++6
without 32
Byte Commander
  • 110,243
adri
