Hello and thanks ahead for reading. I downloaded Deluge on my new Ubuntu 16.04 system running Firefox v48.0 . I downloaded Deluge and can run it if I search for it using the launcher.
I'm trying to open a magnet torrent download link and am getting the "Launch Application" pop up saying:
This link needs to be opened with an application.
Send to:
and I see
Transmission
as my highlighted option and with
Choose an Application__________[Choose...]
I cannot find any appropriate Deluge program in my directories when I click the "Choose" button. I also checked "/myUser/bin/" for it and there is no "deluge" in it as per:
How to open magnet links from firefox with deluge
Can I either find the correct program file to select when this option occurs or preset the default on my system to always launch Deluge every time I click a download link?
Thanks again ahead of time.
Use the following command to help you find the right executable:
sudo find / -iname \*deluge\*
Then you should be able to find the correct executable from the "Choose" box.
Another way of doing that:
In a terminal, enter
 which deluge
That should show you the path to the executable that would be used to open deluge from the terminal.
