I always had this trouble with overheating, but with my upgrade to 16.04 (from 14), it's even worse. The computer fan goes crazy, the temperature rises to 70° without doing anything, so I don't even dare to launch my statistical softwares.
So far I've tried this on my HP Pavilion dv6. Without any improvement. Maybe my problem is not even coming from that.
Any help would be much appreciated, I'd rather avoid to go back to 14.04 and have to reinstall everything...
As requested :
$ lscpu
Architecture:          x86_64
Mode(s) opératoire(s) des processeurs :32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) par cœur : 2
Cœur(s) par socket : 2
Socket(s):             1
Nœud(s) NUMA :       1
Identifiant constructeur :GenuineIntel
Famille de processeur :6
Modèle :             42
Model name:            Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz
Révision :           7
Vitesse du processeur en MHz :2868.093
CPU max MHz:           3000,0000
CPU min MHz:           800,0000
BogoMIPS:              4789.11
Virtualisation :      VT-x
Cache L1d :           32K
Cache L1i :           32K
Cache L2 :            256K
Cache L3 :            3072K
NUMA node0 CPU(s):     0-3
Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm epb tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts
Pierre
/sorry for this I wanted to comment but for some weird reason this page does not let me do that./
I'm not a guide but I read several times problems like that, and the best thing to do is to use a kernel release that is equal to your laptop release date.
I experienced the same heat problem, and compiling old kernel was the solution, maybe you should try that.
In my case deleting ubuntu from my laptop was the best thing to do, maybe ubuntu is not setting things, maybe missing parameters or whatever, I don't know why but windows works like a charm, and just for the problem of heat I returned to windows, now w10 have bash(beta) so I dont see any difference of changing for the simple things i do.
Heat is really a problem because it determines how much time your laptop will live, I've tried mint, fedora and even arch but my problem persisted(also I wanted to try many distros because why not) but finally I decided to go to windows because my work and my life needs that, so Im sure is a kernel problem maybe torvalds doesnt like my laptop =/.
