On 12.04 I used to utilize this procedure, to power off my ATI graphics and prevent my system from overheating, it worked fine. After installing 16.04, I've been trying everything I could find on the net, but no solution. My system runs extremely hot, causing the fans to run at max almost all the time. Can anybody come up with a little hack to shutdown that discrete ATI Radeon card?
thanks. M.Schoofs
System: HP Pavilion dv7-6190ed (FW F.18) [AMD/ATI] Whistler [Radeon HD 6730M/6770M/7690M XT]
Following Neni's answer, I had kernel panic after sleep. I solved my problem by adding radeon.modeset=0 amdgpu.runpm=0 acpi_backlight=intel_backlight to GRUB_CMDLINE_LINUX_DEFAULT
To edit file :
sudo nano /etc/default/grub
Find line :
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
And replace with :
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash radeon.modeset=0 amdgpu.runpm=0 acpi_backlight=intel_backlight"
To regenerate config :
sudo update-grub
Reboot :
sudo reboot
What those options do :
  • radeon.modeset=0 disables radeon driver
  • amdgpu.runpm=0 disables the power management from amdgpu driver
  • acpi_backlight=intel_backlight uses intel driver to control laptop screen backlight
Official bug report suggests as a workaround either manually install newer kernel (which you would have to manually update) or run those steps :
  1. /etc/default/grub: Add amdgpu.runpm=0 to GRUB_CMDLINE_LINUX_DEFAULT
    Included above.
  2. /etc/rc.local: Add the following command:
    echo OFF > /sys/kernel/debug/vgaswitcheroo/switch
    This step caused my system to freeze on shutdown so I just skipped it.
  3. /etc/X11/xorg.conf: Create the file if it doesn't exist, and add the following in order to get the backlight controls working (otherwise it would be misdetected):
    Section "Device"
        Identifier "Card0"
        Driver "intel"
        Option "Backlight" "intel_backlight"
    EndSection
    This step is replaced replaced above by acpi_backlight=intel_backlight
Axtux
  • 101
Check graphic drivers which are in use (radeon/amdgpu should be listed):
lspci -nnk | grep -i vga -A3 | grep 'in use'
Note: If amdgpu is listed, replace radeon with amdgpu in the instructions below!
Open the following file:
gksudo gedit /etc/default/grub
Modify the following line by adding radeon.modeset=0:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash radeon.modeset=0"
Save and Exit
Back to Terminal:
sudo update-grub
sudo reboot
Check again which graphic drivers are in use (radeon/amdgpu should not be listed anymore):
Now, your ATI/AMD graphic card is disabled and your computer works only with the Intel graphics. The fan speed should significantly decrease.
Neni
  • 842
