-1
I have installed Ubuntu 16.04 now in my computer but the problem is the Ubuntu software can't download any apps.
So the solution is to install the any program with terminal but I don't now how ?
dufte
  • 14,198
  • 41
  • 43
Installing via terminal is usually using apt or apt-get.
First of all you need to know what package should be installed, therefor you need to know the package-name.
Assuming you want to install thunderbird you would first of all search for the package name like this
apt search thunderbird
This should output a huge list of packages - locate the proper package ayou are looking for - in our case its simple thunderbird.
Now install the package like this
sudo apt install thunderbird
Finally - i do prefer commandline to install software, but you could as well search for a solution for your base problem - the non working Ubuntu Software application. Therefor it could be helpful to start this software from terminal to get some error-output which could help finding a solution.
dufte
  • 14,198
  • 41
  • 43
