After recent updates, desktop notification sounds stopped working. For example, sounds in pidgin no longer work. But when I go to Pidgin sound preferences and preview the sounds, they work. Also the sound in the applications work fine as usual. Could this be a bug or is there some workaround for this problem?
For me, the solution was to:
- Open
dconf-editor. - Navigate to
org.gnome.desktop.soundand enableevent-sounds.
- 423
using ubuntu 12.04, i installed ubuntu-tweak and on the Tweaks tab, enter the sound section and then enable Event sounds and choose a Sound theme (default "ubuntu").
- 445
You need to add the following startup item to the startup applications.
Step 1: Click on the system menu at the top right of the screen (looks like a wheel)
Step 2: Click on startup applications
Step 3: Click add.
Step 4: Complete with the following:
Name: GNOME Login sound
Command: /usr/bin/canberra-gtk-play --id="desktop-login" --description="GNOME Login"
Comment: Startup Sound
Step 5: Click add.
Step 6: Click close in the bigger box.
Step 7: Log off and log in.
That worked for me.
- 119,640
The problem with Pidgin was that 'Enable sounds' in Tools->Preferences->Sound was set to 'Only when available' and some how my status was set a few days back to away.
As for the other desktop notification sounds like the login sound - I found out that it is an issue with Ubuntu where I have to copy all the sound files from /usr/share/sounds/ubuntu/stereo to /usr/share/sounds. After doing that, the standard Ubuntu login sound played on login.
- 73,717
- 262
Actually, the standard notification sounds, which are set in system settings => sound will not work in Compiz, it seems. But it's not a sound problem; somehow, the actual event is not being sent. This is the sound used for errors or warnings. It includes the visual alerts that can be enabled in system settings => universal access (which has a button that triggers the sound + visual cue).
I found that it works correctly using Metacity, so I entered a bug report to Compiz.
- 18,944
