Recently I had installed Pantheon (Elementary OS desktop environment). I didn't like it, so I uninstalled it, but Elementary OS Desktop still appear in the title bar. And in the shutdown button menu, Ubuntu Help is replaced by Elementary OS Help.
Elementary OS message in Ubuntu desktop
I want that it says Ubuntu Desktop and Ubuntu Help. How do I fix it?
The output of lsb_release -a is:
No LSB modules are available.
Distributor ID: elementary
Description:    elementary OS 0.4 Loki
Release:        0.4
Codename:       loki
For installation, I use:
sudo add-apt-repository ppa:elementary-os/daily
sudo add-apt-repository ppa:elementary-os/os-patches
sudo add-apt-repository ppa:elementary-os/testing
sudo add-apt-repository ppa:mpstark/elementary-tweaks-daily
sudo apt-get update sudo apt-get dist-upgrade sudo apt-get install elementary-theme elementary-icon-theme elementary-default-settings elementary-desktop
For uninstallation, I remove each repository manually, then sudo apt-get autoremove. And the rest with Synaptic Package Manager.
Anwar
  • 77,855
The PPAs you used to install elementary not only provided elementary specific packages, but also patched many standard Ubuntu packages and with your apt-get dist-upgrade command they all get installed and mixed into your system. Which means some of the core packages are not from Ubuntu repository, but from those elementary PPAs.
For example, This ppa https://launchpad.net/~elementary-os/+archive/ubuntu/os-patches provides many packages that are also available in Ubuntu repository. Since the PPA provides those package with higher version (and patched of course), those are preferred by apt and get installed into your system while you did the dist-upgrade command.
For your specific problem, I identified the package which is responsible for showing the distribution name on top-left corner of Unity Panel. It is called base-files. I tested the elementary PPA by installing it and not surprisingly I too got those elementary marks :D.
But to solve this, you just can't remove it, because this is an essential package and Ubuntu needs it. What you need to do is re-installing from Ubuntu repository. Use this command to do so.
sudo apt-get --reinstall install base-files/xenial-updates
This command will install the package from Ubuntu's xenial-updates archive. After a logout and login, you'll see the changes reverted back.
To completely remove Elementary effect from your system, you should go back to Ubuntu versions for all packages. To do so, use ppa-purge (and not apt-add-repository --remove command, which will just remove the repository entry). For example,
sudo ppa-purge ppa:elementary-os/daily
sudo ppa-purge ppa:elementary-os/os-patches
sudo ppa-purge ppa:elementary-os/testing
sudo ppa-purge ppa:mpstark/elementary-tweaks-daily
ppa-purge will remove packages from these PPAs and install the ones from Ubuntu archives.
Note: If you already removed the Elementary PPA entries (by deleting the lines from sources.list files) add them again and then use ppa-purge.
Anwar
  • 77,855
To change the information related to your distribution release and codename, edit the file /etc/lsb-release:
gksu gedit /etc/lsb-release
Mine contains the following information:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.1 LTS"
