I've got X11 forwarding on so I can see program windows on my server from my desktop, I'm wondering if I disconnect from the ssh session with the x11 forwarding to my PC, will that program close on the server side upon disconnecting? If it does, is there a way to prevent that?
I have MEGASync running on my server and it needs an X server running to use it, I cannot use VNC because iptables is acting strangely, can't open the port properly. I'd like to keep megasync running on the server without having to stay connected to SSH so I can turn my PC off.
Any way to do this?
BitRain
  • 73
Xpra seems to be exactly what you are looking for. It's a bit like screen or tmux but for X11 applications.
See this answer on http://unix.stackexchange.com for an example.
There are 2 avenues I would explore. the simplest is just to keep the ssh alive by adding ServerAliveInterval 60 to your ssh client config
cat <<- EOF >> $HOME/.ssh/config
    # send packets over ssh every 60 seconds to keep ssh connection alive
EOF
or alternatively install screen or tmux, personally I use tmux
so on the server you would need to run
sudo apt-get install tmux
then launch tmux on server
tmux -2
connect to the server with
ssh -X -C -c blowfish-cbc,arcfour [-pPORT_NUM] user@1.2.3.4
where
  • -X Enables X11 forwarding.
  • -C Requests compression of all data (including stdin, stdout, stderr, and data for forwarded X11, TCP and UNIX-domain connec‐ tions).
  • -c is the cipher type
the compression stuff is not essentially but reduces lagginess/responsiveness with the server
Then launch your program from inside the tmux session
i.e.
$ your program
if your ssh gets disconnected, the program should remain running on the server, to reconnect with the program once you get a new ssh connection going, run
tmux attach
on the server
