Which Robot operating System (ROS) distribution can be installed on Beagle Bone Black with Ubuntu 16.04?
ROS on Ubuntu supports armhf and arm64 as well as the amd64 architecture. There is a ROS release every year in May. Every ROS release will be supported on exactly one Ubuntu LTS. ROS releases will drop support for EOL (End Of Life) Ubuntu distributions, even if the ROS release is still supported. The ROS Kinetic release is currently supported only on Ubuntu 16.04. ROS Noetic is slated to be the last ROS 1 release, and officially will not support anything beyond Ubuntu 20.04.
The following ROS 2 releases are currently available.
  • Released in May 2022, ROS 2 Humble is a Long Term Support (LTS) release with extended support until May, 2027. This makes it a good choice for projects requiring stability and long-term use.
  • ROS 2 Iron is the newest ROS 2 release, launched on May 23, 2023. Its End-of-Life (EOL) is expected in November, 2024 since it's a normal release with a shorter term of support of 1.5 years.
ROS installation in Ubuntu 22.04 and later
ROS Noetic is slated to be the last ROS 1 release, and officially will not support anything beyond Ubuntu 20.04. To install ROS 2 in Ubuntu 22.04 and later run the following commands.
  1. To install ROS 2 in Ubuntu 22.04 and later open the terminal and type:
sudo apt install software-properties-common
sudo add-apt-repository universe
sudo apt update && sudo apt install curl -y
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
  1. Add the ROS 2 repository to your software sources.
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" | sudo tee /etc/apt/sources.list.d/ros2.list > /dev/null
sudo apt update
sudo apt upgrade
  1. Install ROS 2 packages.
    ROS 2 packages are built on frequently updated Ubuntu systems. It is always recommended that you ensure your system is up to date before installing new packages. Choose from the following options for installing ROS 2 packages.
    • Desktop install (Recommended): ROS, RViz, demos, tutorials
      sudo apt install ros-humble-desktop
    • ROS-Base install (Bare Bones): Communication libraries, message packages, command line tools. No GUI tools.
      sudo apt install ros-humble-ros-base
    • Development tools: Compilers and other tools to build ROS packages
      sudo apt install ros-dev-tools
ROS Noetic installation in Ubuntu 20.04
  1. Configure your Ubuntu repositories to allow restricted, universe and multiverse.
  2. Run these commands:
     sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
     sudo apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
     sudo apt update
  3. Select one of four default ROS configurations.
     sudo apt install ros-noetic-desktop-full # full desktop
     sudo apt install ros-noetic-desktop # desktop install
     sudo apt install ros-noetic-ros-base # no GUI
     sudo apt install ros-noetic-PACKAGE # individual package installation
    To find available packages, use: apt-cache search ros-melodic and then replace PACKAGE in ros-melodic-PACKAGE by one of the available packages found by apt-cache search ros-melodic
  4. Initialize rosdep. rosdep enables you to easily install system dependencies for source you want to compile and is required to run some core components in ROS.
     sudo rosdep init
     rosdep update
  5. Environment setup
     echo "source /opt/ros/noetic/setup.bash" >> ~/.bashrc
     source ~/.bashrc
  6. Get rosinstall. rosinstall enables you to easily download many source trees for ROS packages with one command.
     sudo apt install python-rosinstall-generator python-wstool build-essential
  7. To test your installation, visit the official ROS Tutorials.
Source: Ubuntu install of ROS Kinetic, Ubuntu install of ROS Melodic, Ubuntu install of ROS Noetic
ROS Melodic installation in Ubuntu 18.04
     sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key 421C365BD9FF1F717815A3895523BAEEB01FA116
     sudo apt update
     sudo apt install ros-melodic-desktop-full # full desktop
     sudo apt install ros-melodic-desktop # desktop install
     sudo apt install ros-melodic-ros-base # no GUI
     sudo apt install ros-melodic-PACKAGE # individual package installation
     sudo rosdep init
     rosdep update
     echo "source /opt/ros/melodic/setup.bash" >> ~/.bashrc
     source ~/.bashrc
ROS Kinetic installation in Ubuntu 16.04
     sudo apt-key adv --keyserver hkp://ha.pool.sks-keyservers.net:80 --recv-key 0xB01FA116
     sudo apt update
     sudo apt install ros-kinetic-desktop-full # full desktop
     sudo apt install ros-kinetic-desktop # desktop install
     sudo apt install ros-kinetic-ros-base # no GUI
     sudo apt install ros-kinetic-PACKAGE # individual package installation
    To find available packages, use: apt-cache search ros-kinetic and then replace PACKAGE in ros-kinetic-PACKAGE by one of the available packages found by apt-cache search ros-kinetic
     sudo rosdep init
     rosdep update
     echo "source /opt/ros/kinetic/setup.bash" >> ~/.bashrc
     source ~/.bashrc
karel
  • 122,292
  • 133
  • 301
  • 332
