-1
A lot of packages are still not supported in ros noetic, so i was trying to build melodic from source in ubuntu 20.04. While following instructions from here, i got stuck in this command rosdep install --from-paths src --ignore-src --rosdistro melodic -y
The errors i got were:-
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: laser_geometry: No definition of [python-numpy] for OS version [focal] genpy: No definition of [python-yaml] for OS version [focal] gencpp: No definition of [python-setuptools] for OS version [focal] python_orocos_kdl: No definition of [python-sip] for OS version [focal]
I understand that these are because ubuntu 20.04 doesnt have python in it. So i tried doing
  1. alias python=python3 in my bashrc
  2. sudo update-alternatives --install /usr/bin/python python /usr/bin/python3 10
but i still receive these errors. How to resolve these issues? Even if i sudo apt-get install all these packages, still these erros are present.
mmmmk
Towards answering your question...
I began down the path suggested by @HimnashuTanwar, building melodic from source, but ultimately concluded that a full ros melodic install is not viable in 20.04.
A few notes:
  • Adding a -r to the rosdep command immediately exposed all of the
    dependencies related to Python2 Most such dependencies could be met
    using pip install -U [package].
  • A notable exception was pyqt5, which in turn depended on sip. At first I endeavored to build the sources of these two, as per https://www.riverbankcomputing.com/static/Docs/PyQt5/installation.html#building-and-installing-from-source, but settled on this solution instead: How to get PyQt5 for Python2 on Ubuntu 20.04
  • What caused me to abandon the build was a nasty dependence of
    melodic's tf2 on an earlier version of Boost. It turns out that 20.04 runs on libboost1.71, wherein boost-signals has been deprecated and deleted, and this breaks the build of tf2 -- this issue is of course remedied in Noetic.
So in the end, it's probably best to stick with the supported version pairs: melodic on 18.04 or noetic on 20.04+, as per (http://wiki.ros.org/Distributions)
stefan
Try this:
rosdep install --from-paths src --ignore-src --rosdistro melodic --os=ubuntu:bionic -y
Apart from that, melodic uses python2, which isn't in focal. So install python2, pip and other dependencies. After that, update-alternatives to python2 and pip2.
I haven't tried it yet; you may comment for further problems.
