I am low on disk space and when I check the Disk Usage analyzer (using gksudo baobab) it indicates that my home/teddy folder is using 94GB, but when I browse through its contents I can only account for about 1gb of that usage. I've tried sudo apt-get clean and deleting the cached package files from Synaptic Package Manager, emptied trash but that has not changed the amount of free space I have.
Disk use
It seems similar to this problem But using the root disk usage analyzer has not given any insight into what is consuming so much space.
Any ideas?
tedtoy
  • 73
Looks like there is a very big file in /home/teddy. You can look for it either in Nautilus, checking view hidden files, list view and ordering by size, or from the command line:
du -a --max-depth=1 ~ | sort -n
The last entry before the home dir itself should be the biggest file.
du reports the file size of the first argument and all it's subdirs.
  • -a makes it show all files and dirs
  • --max-depth=1 keeps it from looking on all subdirs.
sort will sort the results
  • -n they will be sorted numerically.
Javier Rivera
  • 35,434
If you think you have some gigantic files that disk analyzer is not seeing for some reason, you may use ls to look for large files. Try this for example: ls -alrS in your home folder.
Is this a wubi installatoin shared with win32 files? A few weeks ago I encountered a similar issue on a wubi system that was installed by a friend. As it is in your case, the disk analyzer was showing a really high value for home folder, much more than the sum of its sub-folders. I cant comment on why disk analyser was behaving in this way, but the approach I took in my case was to do a clean install of Ubuntu on a dedicated partition. Of course that is not a very good solution, but if this is a relatively new system, it might be a reasonable workaround.
Hopefully someone else can shed some light on why disk analyzer is behaving in this way, and how to make that disk space available.
Aras
  • 819
I was baffled by my disksystem all the same, telling me a cp -r /home would not work cause there is no space left (moving 840MB to a "2.9GB free" partitition).
The meat of the story is: du did not find a subdir "Öffentlich" and did not count the files inside it.
For those interested - thats what I found : du told me 840 MB used (Disk Usage analyzer the same)
df told me 5,3 GB used
I found various tips revolving around
lsof -n | grab deleted    (to find out wether there are any "deleted yet open" files hugging space)
sudo tune2fs -l /dev/sda1 | grep 'Block size'  (to find out the block size 4k in my case)
find /home -size -4k | wc -l    (to find out the number of files smaller than 1 block, a 10 bytes file using a 4046 block is wasting lots a space)
du -sh ./*   (finding the space used (real size) in each subdir)
df -i        (finding not the number of used blocks, but the no of used inodes, whats it worth for, I am not sure yet.)
Further tips found :
Disk Usage Analyzer is rights-aware - "sudo baobab" will show more than "baobab"
du -c --max-depth=4 /dir | sort -n
ncdu utility found at: http://dev.yorhel.nl/ncdu
The best tip for me was du -sh. It helped me find following directory, which was not "cumulated" into the du / sum. /home/mine/pictures/Öffentlich (german O-Umlaut)
At first I thought that was for the "O-Umlaut", but copying /home to a new partition solved that for me.
Good luck hunting.
Josch
because u install Ubuntu from windows wubi installation u choose the space u want in advance say 10 giga when u reach this space u will have low disk space even your drive is still have more memory ,as drive i mean the partition u install the release on it
in linux i prefer to install it from cd ,or from wubi with determine an enough space to ur relaese :D :D
htorque
  • 66,086
