I have a HP EliteBook 2540p laptop. I have a ubuntu 16.04 and Windows 10 dual boot. In Linux whenever I press the M button the mouse stops working on all of the other pages except the one I'm at. I noticed that in windows this happens if I enable the round button in the middle of keyboard and the two right and left click on top of the touchpad. how can i disable these in ubuntu.
Asked
Active
Viewed 771 times
So i managed to figure out a solution. run this command
xmodmap -e 'pointer = 1 0 2 3 4 5 0 0 0 0 0 0 0'
this command will disable the second button which is middle click. the touch pad doesn't have a middle click but some how when you press the extra clicks on top of the touch pad this the OS thinks you are holding the button down which causes some trouble including mouse malfunction in some areas.
The settings for the mouse will return to their default state so your gonna have to do this each time on startup.
