I am unable to install or upgrade anything on Ubuntu 16.04.I am missing package python3-software-properties and can't install it anyhow . I have posted the various tracebacks. I tried installing these packages and got these errors.
sarfraz@sarfraz:~$ sudo apt-get install --reinstall dpkg
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
language-selector-common language-selector-gnome python3-distupgrade
python3-software-properties software-properties-common software-  properties-gtk
Recommended packages:
unattended-upgrades
The following packages will be upgraded:language-selector-common
language-selector-gnome python3-distupgrade python3-software-
properties software-properties-common software-properties-gtk
6 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 30 not     upgraded.
 141 not fully installed or removed.
Need to get 2,083 kB/2,496 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://in.archive.ubuntu.com/ubuntu xenial-updates/main amd64     dpkg amd64 1.18.4ubuntu1.1 [2,083 kB]
Fetched 2,083 kB in 3s (617 kB/s)
(Reading database ... 220260 files and directories currently installed.)
Preparing to unpack .../language-selector-gnome_0.165.4_all.deb ...
/var/lib/dpkg/info/language-selector-gnome.prerm: 6:         /var/lib/dpkg/info/language-selector-gnome.prerm: py3clean: not found
dpkg: warning: subprocess old pre-removal script returned error exit    status 127
dpkg: trying script from the new package instead ...
/var/lib/dpkg/tmp.ci/prerm: 6: /var/lib/dpkg/tmp.ci/prerm: py3clean:  not found
dpkg: error processing archive /var/cache/apt/archives/language-selector-gnome_0.165.4_all.deb (--unpack):
 subprocess new pre-removal script returned error exit status 127
/var/lib/dpkg/info/language-selector-gnome.postinst: 6:     /var/lib/dpkg/info/language-selector-gnome.postinst: py3compile: not found
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 127
Preparing to unpack .../dpkg_1.18.4ubuntu1.1_amd64.deb ...
Unpacking dpkg (1.18.4ubuntu1.1) over (1.18.4ubuntu1.1) ...
sarfraz@sarfraz:~$ sudo apt-get install python3-minimal
python3-minimal is already the newest version (3.5.1-3).
  unattended-upgrades
  language-selector-common language-selector-gnome python3-distupgrade  python3-software-properties software-properties-common software- properties-gtk
6 upgraded, 0 newly installed, 0 to remove and 30 not upgraded.
Need to get 0 B/413 kB of archives.
dpkg: error processing archive /var/cache/apt/archives/language-    selector-gnome_0.165.4_all.deb (--unpack):
Preparing to unpack .../language-selector-common_0.165.4_all.deb ...
/var/lib/dpkg/info/language-selector-common.prerm: 21:     /var/lib/dpkg/info/language-selector-common.prerm: py3clean: not found
/var/lib/dpkg/tmp.ci/prerm: 21: /var/lib/dpkg/tmp.ci/prerm: py3clean: not found
dpkg: error processing archive /var/cache/apt/archives/language-    selector-common_0.165.4_all.deb (--unpack):
/var/lib/dpkg/info/language-selector-common.postinst: 23:    /var/lib/dpkg/info/language-selector-common.postinst: py3compile: not   found
 /var/cache/apt/archives/language-selector-common_0.165.4_all.deb
sarfraz@sarfraz:~$ sudo apt-get install libssl-dev openssl
libssl-dev is already the newest version (1.0.2g-1ubuntu4.1).
openssl is already the newest version (1.0.2g-1ubuntu4.1).
  unattended-upgrades
dpkg: error processing archive /var/cache/apt/archives/language-selector-common_0.165.4_all.deb (--unpack):
sarfraz@sarfraz:~$ sudo apt-get update && sudo apt-get dist-upgrade -y
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://dl.google.com/linux/chrome/deb stable Release
Hit:4 http://ppa.launchpad.net/mystic-mirage/pycharm/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/webupd8team/sublime-text-3/ubuntu xenial InRelease
E: The package python3-software-properties needs to be reinstalled, but I can't find an archive for it.
sarfraz@sarfraz:~$ sudo apt-get install --reinstall python-software-properties
sarfraz@sarfraz:~$ sudo apt-get install software-properties-common
sarfraz@sarfraz:~$ sudo apt-get install --reinstall python3-software-properties
sarfraz@sarfraz:~$ sudo dpkg -i Downloads/python3-software-properties_0.92.36_all.deb
Preparing to unpack .../python3-software-properties_0.92.36_all.deb ...
/var/lib/dpkg/info/python3-software-properties.prerm: 6:     /var/lib/dpkg/info/python3-software-properties.prerm: py3clean: not found
dpkg: error processing archive Downloads/python3-software-    properties_0.92.36_all.deb (--install):
 subprocess installed pre-removal script returned error exit status 127
/var/lib/dpkg/info/python3-software-properties.postinst: 6:      /var/lib/dpkg/info/python3-software-properties.postinst: py3compile: not found
Help will be appreciated.
5 Answers5
Try running the following command:
apt-get  -f install
to correct a system with broken dependencies in place.
Try also: dpkg --configure -a.
If above won't help, try reinstalling your core Python installation as py3compile file is part of python3-minimal package, so if you still got the problem, try reinstalling that package. If you can't reinstall using apt-get, try to download .pkg file from kernel.org and install manually (python3-minimal*). E.g.
dpkg -i python3-minimal_*.deb
Also make sure that py3compile is accessible based on your current PATH variable.
kenorb
  • 10,944
I know this is an old thread, but I was able to resolve my broken Python3 system installation with sudo apt install python3-minimal python3 --reinstall
This is what worked for me:
First I installed python3-all to reinstall Python and anything else missing as per this answer: https://askubuntu.com/a/810914/640078
sudo apt install python3-all
This installed most of the stuff, but with a couple of issues; I proceeded as follows:
I did sudo apt -f install, and got several errors like this:
Need to get 0 B/183 kB of archives.
After this operation, 0 B of additional disk space will be used.
dpkg: error processing package python3-yaml (--configure):
 package is in a very bad inconsistent state; you should
 reinstall it before attempting configuration
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: error processing package update-notifier (--configure):
 dependency problems - leaving unconfigured
 python3-yaml
 netplan.io
 ubuntu-advantage-tools
 update-manager
 ubuntu-release-upgrader-gtk
 update-notifier
So I installed python3-yaml first, then ubuntu-advantage-tools:
sudo apt install python3-yaml
sudo apt install ubuntu-advantage-tools
I then did sudo apt install -f and sudo apt autoremove and that fixed it.
Best answer is to reinstall. But i managed to fix this--
Install python on any other machine i.e VPS apt install python python3 python-all python-minimal python3-minimal
Once you have pythone installed on your VPS or another PC.
cd /var/lib zip -r fix.zip dpkg
Now copy this file(from VPS download) to your system at /var/lib unzip fiz.zip Press A to overwrite ALL
Now on your machine apt install python3-all python3-minimal --reinstall apt autoremove
FIXED
Just had this issue on 24.04. Some people mentioned accidentally deleting the built-in Python (on a Chinese site CSDN), but eventually this was resolved by ensuring /usr/bin/python3 links to a python program. Previously I had /usr/bin/py as a shorthand but apparently that got apt confused.
Tl;dr: to fix, try running:
sudo ln -s /usr/bin/python3.12 /usr/bin/python3
