I am on dual boot with Windows 10.
I initially had Ubuntu 18.04 and updated to Ubuntu 20.04 last month. I usually run the software updater from time to time.
Last week, I ran the software updater and it updated and some ubuntu base files along with some software. It asked for a reboot after and so rebooted.
I tried some responses already in askubuntu and few other sites but none worked. Anyway, here is the problem.
Today, I see that software-updater, terminal are not working.
I tried the following already:
sudo apt-get update
It gave the following error:
sh 1: /usr/lib/cnf-update-db: not found
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
Then following some other posts, I tried checking for python and all I see is python2.7 is the only one present. I know that python3 was installed when it was upgraded to Ubuntu 20.04 but after the last week's update, I am not sure how it is gone. Anyway, I tried to install the python3-minimal using the following command:
sudo apt-get install --reinstall python3-minimal
and this did not work giving the errors saying unmet dependencies for python3-samba and python3-uno and suggested to use the following command
sudo apt --fix-broken install
This also gave the following error:
Error encountered while processing:
/var/cache/apt/archives/python3-distupgrade_1%3a20.04.19_all.deb
/var/cache/apt/archives/python3-samba_2%3a4.11.6+dfsg_0ubuntu1.2_amd64.deb
/var/cache/apt/archives/python3-uno_1%3a6.4.3_0ubuntu0.20.04.1_amd64.deb
In relation to this above error, it complains about py3clean and py3compile not found.
At this point, I am not sure how to fix this.
Can someone please help fixing this.
Thanks.
