34
I know that asking for something like Visual Studio is too much but something that will let me write, debug and compile in a GUI instead of the command line is good enough for me. (Not that I'm lazy, but I don't have time to learn the necessary commands...)
andrew.46
  • 39,359
david25
  • 2,227
15 Answers15
28
Code::Blocks
sudo apt install codeblocks
alt text
Wikipedia: Code::Blocks
karel
  • 122,292
  • 133
  • 301
  • 332
lovinglinux
  • 6,427
26
Geany
Geany is a text editor using the GTK2 toolkit with basic features of an integrated development environment. It was developed to provide a small and fast IDE, which has only a few dependencies from other packages. It supports many filetypes and has some nice features.
To install geany in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install geany
alt text
karel
  • 122,292
  • 133
  • 301
  • 332
hhlp
  • 42,872
26
Eclipse
Eclipse with Eclipse IDE for C/C++ Developers.
This package includes:
  • C/C++ Development Tools
  • Git integration for Eclipse
Regardless of your operating system, you will need to install some Java virtual machine (JVM). You may either install a Java Runtime Environment (JRE), or a Java Development Kit (JDK), depending on what you want to do with Eclipse. If you intend to use Eclipse for Java development, then you should install a JDK. If you aren't planning to use Eclipse for Java development and want to save some disk space, install a JRE.
If you are using Linux, read this.
karel
  • 122,292
  • 133
  • 301
  • 332
Vassilis
  • 2,957
18
MonoDevelop
If you like Visual Studio, you will certainly like MonoDevelop. You can find it in the Software Center. You can even write .NET apps with it if you want to (like C# as you can see in the screenshot), but I suggest you don't.
To install MonoDevelop in Ubuntu 14.04-16.04 open the terminal and type:
sudo apt install monodevelop
MonoDevelop]2
karel
  • 122,292
  • 133
  • 301
  • 332
W. Goeman
  • 1,580
16
CodeLite
CodeLite is a powerful and lightweight IDE specializing in C, C++, PHP and JavaScript. Its features include:
  • Generic support for compilers
  • Built-in GDB support
  • Database-based Code Completion mechanism
  • Syntax highlighting for C/C++, Java, Perl, XML, Makefile, Lua, Diff files, PHP, JavaScript, Python, HTML, and ASP
  • Text Folding
  • Bookmarks
  • Find and Replace
  • doxygen comment generator
To install CodeLite in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install codelite
alt text
CodeLite screenshot gallery
For me CodeLite is the best replacement for Visual Studio.
karel
  • 122,292
  • 133
  • 301
  • 332
lukasz
  • 2,436
13
NetBeans
Apache NetBeans IDE lets you quickly and easily develop Java desktop, Java EE, and web applications, as well as HTML5 applications with HTML, JavaScript, and CSS. The IDE also provides a great set of tools for PHP and C/C++ developers. To install NetBeans in all currently supported versions of Ubuntu open the terminal and type:
sudo snap install netbeans --classic
karel
  • 122,292
  • 133
  • 301
  • 332
lovinglinux
  • 6,427
13
vim Install vim
Vim is also a good choice for writing C programs.
Zanna
  • 72,312
12
Anjuta
Anjuta is a versatile software development studio featuring a number of advanced programming facilities including project management, application wizard, interactive debugger, source editor, version control, GUI designer, profiler and many more tools. It focuses on providing simple and usable user interface, yet powerful for efficient development.
To install Anjuta in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install anjuta
alt text
karel
  • 122,292
  • 133
  • 301
  • 332
hhlp
  • 42,872
Emacs
Install emacs-gtk for the version which supports good readable freetype fonts, gtk and other visual goodies.
Emacs allows you to compile and debug inside the GUI. With CEDET package, it has got nice code completion for C and C++ projects. Color theme will give nice themes and syntax coloring for the source code. Emacs can be customized heavily using the e-lisp.
Emacs running with CEDET and color theme showing code completion.
Also refer to Ubuntu Community Help Wiki for EmacsHowto.
karel
  • 122,292
  • 133
  • 301
  • 332
KDevelop
I very highly recommend KDevelop. It's a KDE program, but it will work under GNOME. It's like a color explosion. Pretty much every single variable, class, method, language construct, etc. has a different color. Not just local variables one color, global, etc. Every local variable will have a different color from each other one.
It also integrates with cmake extremely well and is generally a great IDE to work with. I really wish there was a Java and/or Python plugin for it.
To install KDevelop in all currently supported versions of Ubuntu open the terminal and type:
sudo apt install kdevelop
screenshot
karel
  • 122,292
  • 133
  • 301
  • 332
Falmarri
  • 171
qtcreator Install qtcreator
QT Creator is the best C/C++ IDE available for Ubuntu.
Qt Creator is a cross-platform C++ integrated development environment which is part of the Qt SDK[2]. It includes a visual debugger and an integrated GUI layout and forms designer. The editor's features includes syntax highlighting and autocompletion, but not tabs. Qt Creator uses the C++ compiler from the GNU Compiler Collection on Linux and FreeBSD. On Windows it can use MinGW or MSVC with the default install and can also use cdb when compiled from source.
Zanna
  • 72,312
Tachyons
  • 17,455
Sublime Text 2
I recommend Sublime Text 2. It is not free but worth every cent.
Sublime Text 2 may be downloaded and evaluated for free, however a license must be purchased for continued use. There is currently no enforced time limit for the evaluation.
It features a plethora of useful features and is highly extensible.
Octavian Helm
  • 14,515
Eclipse
Just for completeness I suggest you take a look at Eclipse. To install Eclipse in all currently supported versions of Ubuntu open the terminal and type:
sudo snap install eclipse --classic
Eclipse can handle just about any language you like with the right plugin, but in my opinion better options have already been mentioned in this list.
karel
  • 122,292
  • 133
  • 301
  • 332
richzilla
  • 12,185
One more good editor and awarded is Komodo Edit. You can use it with a lot languagies c, c++, python and more. Is free and croos platform.
There is a Komodo IDE but it is commercial and non-free. You can try it with a trial version.
Zanna
  • 72,312
Vassilis
  • 2,957
Anjuta DevStudio
Anjuta IDE for C/C++ and GNOME/Gtk+ applications has features that enable easy debugging, management of code and GUI design by providing a simple and usable user interface. It also integrates with version control systems like CVS, Git or Subversion.
karel
  • 122,292
  • 133
  • 301
  • 332
mgunes
  • 9,910
