When I install Steam it tells me that it couldn't set up Steam data. I looked that up and the solutions that I found include deleting the .steam folder so that it makes one from fresh. But I don't have a .steam folder, no matter how I install Steam (.deb file installation or using the terminal).
When I use the terminal to launch it, it tells me this:
Repairing installation, linking /home/nik/.steam/steam to /home/nik/.local/share/Steam
rm: cannot remove '/home/nik/.steam/steam': Is a directory
Setting up Steam content in /home/nik/.local/share/Steam
According to those command outputs, you do have a .steam directory, but it is hidden (because it starts with a .)
Use ls -d .* to show all hidden files or ls -A to show all files
The error is a directory is giving you a hint that you need to use the -r (recursive) flag to remove directories
rm -r .steam
But that is probably NOT the best way to fix your Steam issues. Try this or read this thread for better solutions.
Zanna
  • 72,312
