After a botched upgrade from Ubuntu 14.04 to Ubuntu 16.04 I had to wipe my system and start all over. This time I decided to go with a much less CPU intensive desktop environment and installed Lubuntu 16.04-1.
My problem: when I run Steam from the menu shortcut it acts like it is doing nothing. However it does show up in the task manager. If I just type steam in the terminal I get the following.
michael@michael-HP-Pavilion-dm1-Notebook-PC:~$ steam
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
grep: symbol lookup error: grep: undefined symbol: pcre_jit_stack_alloc
/bin/bash: /home/michael/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/lib/x86_64-linux-gnu/libtinfo.so.5: no version information available (required by /bin/bash)
awk: /home/michael/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/lib/x86_64-linux-gnu/libtinfo.so.5: no version information available (required by /lib/x86_64-linux-gnu/libreadline.so.6)
Installing breakpad exception handler for appid(steam)/version(1468023329)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Then nothing happens including steam doesn't show up in the task manager. Now I did find the command.
LD_PRELOAD='/usr/$LIB/libstdc++.so.6' DISPLAY=:0 steam
This does run Steam but it is not a real solution in my eyes. How can I fix it?
