Is it possible to install tomcat6 in ubuntu 16.04? does ubuntu 16.04 supports tomcat6? when I try to install tomcat 6 using apt-get install i got the following message
Reading package lists... Done
Building dependency tree
E: Unable to locate package tomcat6
and when I try to install libtomcat6-java got following message.
Package libtomcat6-java is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libtomcat6-java' has no installation candidate
help me to install tomcat6 using apt-get Thank You.
Satya N
You'll have to download the tar file, decompress and move to a directory of your choice. You can choose a mirror here and get a different download link.
My steps:
$ wget http://ftp.unicamp.br/pub/apache/tomcat/tomcat-6/v6.0.53/bin/apache-tomcat-6.0.53.tar.gz
$ tar xvzf apache-tomcat-6.0.47.tar.gz
$ sudo mkdir /usr/local/tomcat
$ sudo mv apache-tomcat-6.0.47 /usr/local/tomcat
I'm almost sure that Tomcat 6 works in Java 6, so additional steps are required if your Ubuntu is using, for instance, Java 8.
As Java 6 is no longer distributed for Ubuntu, you'll need to download a legacy package and install manually, according to this answer.
$ chmod a+x jdk-6u45-linux-x64.bin
$ sudo ./jdk-6u45-linux-x64.bin
$ mv jdk1.6.0_45 java-6-oracle
$ sudo mv java-6-oracle /usr/lib/jvm
And now, you can switch java version using either update-alternatives or galternatives.
Additionally, modify your .bashrc file to set JAVA_HOME variable:
export JAVA_HOME=/usr/lib/jvm/java-6-oracle
For 6 the apt-get command is
sudo apt-get install tomcat6
I don't know if that version is still in the repo for Ubuntu 16.04. Otherwise you have to download the tar bundle and install it from there.
  • Why do you need 6, not 7 or 8?
  • Why are you limited to apt-get?
Manual install is not that difficult if I remember correctly. You should however record precisely what you're doing and copy all config files you edited as backup. When you need to upgrade, you want to know how you did it the first time.
SPRBRN
  • 2,535
