I am running VirtualBox Version 5.0.22 with Ubuntu 16.04. I performed an update today and then got into the problem that has happened to so many others:
Icons&menys dissapeared.
There is a thread for this discussed here:
Unity doesn't load, no Launcher, no Dash appears
But, I believe I have tried everything discussed in that thread, like:
sudo service lightdm stop rm ~/.config/dconf/user sudo service lightdm start
and:
sudo apt-get install --reinstall ubuntu-desktop sudo apt-get install unity
and:
using unity-tweak-tool.
and:
and enable Unity using ccsm,
and
export DISPLAY=:0
sudo dconf reset -f /org/compiz/ setsid unity
and other suggestions presented:
but nothing seem to works.
Anyone else who have run into this?
Someone who have a suggestion not already discussed or have a proposal of a solution already presented, that needs some tweaking for 16.04 ?
I had the same problem and none of the solutions worked. Until I found this answer which was posted just 5 hours ago.
Delete your .cache folder in your home directory and reboot. It also deletes your settings and locked launch bar icons but that is no big deal.
lamyarus
