So, I was trying to install Arch in my system, which already had a dual-boot with Ubuntu 14.04 and Windows 10 installed. The installation went wrong, so I deleted both root and swap partitions from Arch. I had some problems first because my computer was using Arch's grub installation to boot, so I was always entering in grub recovery mod, which I fixer after changing boot order by putting Ubuntu on top again.
My problem is even though I run sudo update-grub from Ubuntu terminal, at grub menu, the Arch option is still there, with its advanced options. I tried to delete the arch_boot folder from /boot/efi/EFI directory but it didn't change.
How can I get rid of this? I want to try to make an another Arch installation, but I get the feeling that this entry at grub menu will disturb me. Then, what should I do? Thanks in advance.
d a i s y
  • 5,551
Re-install Grub
sudo grub-install path/to/root/disk
Grub auto-detects operative systems during installation. I think it will also detect outside the disk you install it on, Like if you have a Live USB plugged that is not the booted system it will include it too.
I have mine in /dev/sda
sudo grub-install /dev/sda
Open Disks app and look for the partition that shows (Bootable):
Live CD installation Video
userDepth
  • 2,040
Alright, here's what I did: I had the idea to generate another grub.cfg using the following command at terminal:
grub-mkconfig -o /boot/grub/grub.cfg
It just gave me a different error when I tried to boot in Arch. It couldn't detect its kernel. So I put Arch on top of the boot order again and executed the same command there. This time, it detected Windows 10 installation(which was weird, because it didn't detected it first time I ran this command when I was configuring Arch's boot loader). Now Arch's grub is working fine, except by the fact that when I select Ubuntu at the menu, it gives me this annoying message for some seconds before it boots:
Ignoring BGRT: invalid status 0 (expected 1)
But I guess the topic problem is now solved.
In my case I wanted to remove the Windows option : removed Microsoft directory (rm -r) from the /boot/efi/EFI/ directory, and updated grub as suggested in the previous answers. Windows entry is gone : maybe a bit messy but worked fine.
