After upgrading to Ubuntu 16.04 kmymoney was removed, now cannot be re-installed.
I've tried from Ubuntu software centre and terminal with sudo apt-get install but I get this. How do I proceed to install? I need to access my accounts.
The following packages have unmet dependencies.
 kmymoney : Depends: kde-runtime (> 4:4.10) but it is not going to be installed
Depends: libkabc4 (>= 4:4.4.4) but it is not going to be installed
Depends: libkfile4 (>= 4:4.4.4) but it is not going to be installed
Depends: libkhtml5 (>= 4:4.4.4) but it is not going to be installed
Depends: libkio5 (>= 4:4.4.4) but it is not going to be installed
howard@coaching:~$
Run the following commands in terminal:
sudo apt-get update
sudo apt-get install kmymoney
control + alt + T to open terminal
storm
  • 5,013
-1
After running these commands:
sudo apt-get update
The app will be installed, but will not appear on the launcher. click on "search your computer" and in the search window click the "A" at the bottom:
  1. You will see a display of installed apps - click on "see more results".
  2. You will then see the installed kmymoney. Click it and the app will open.
  3. The icon will now appear on the launcher. To keep it there, right click it and choose "lock to launcher".
Job done!
George Udosen
  • 37,534
