Introduction
The following script allows selecting two windows, and while both windows are open, it will raise both windows when user focuses either one. For instance, if one links widows A and B , witching to either A or B will make both raise above other widows.
To stop the script you can use killall link_windows.py in terminal , or close and reopen one of the windows. You can also cancel execution by pressing close button X on either of the window-selection popup dialogs.
Potential tweaks:
- multiple instances of the script can be used to group pairs of two windows. For example, if we have windows A,B,C,and D we can link A and B together, and link C and D together.
- multiple windows can be grouped under one single window. For example, if I link window B to A, C to A, and D to A , that means if I always switch to A , I can raise all 4 windows at the same time.
Usage
Run the script as:
python link_windows.py
The script is compatible with Python 3 , so it can also run as
python3 link_windows.py
There are two command line options:
--quiet or -q , allows silencing down the GUI windows. With this option you can just click with mouse on any two windows , and the script will begin linking those.
--help or -h, prints the usage and description information.
The -h option produces the following information:
$ python3 link_windows.py -h
usage: link_windows.py [-h] [--quiet]
Linker for two X11 windows.Allows raising two user selected windows together
optional arguments:
-h, --help show this help message and exit
-q, --quiet Blocks GUI dialogs.
Additional technical information can be viewed via pydoc ./link_windows.py , where ./ signifies that you must be in the same directory as the script.
Simple usage process for two windows:
A popup will appear asking you to select a window #1 , press OK or hit Enter. The mouse pointer will turn in to a cross. Click on one of the windows you want to link.
A second popup will appear asking you to select window #2,press OK or hit Enter. Again, the mouse pointer will turn into a cross.Click on the other window you want to link. After that execution will begin.
Whenever you focus either window, the script will raise the other window up, but return focus to the one originally selected ( note - with a quarter of a second delay for best performance ) , thus creating feel that windows are linked together.
If you select the same window both times, the script will quit. If at any moment you click close button of popup dialog , the script will quit.
Script source
Also available as GitHub Gist
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Author: Sergiy Kolodyazhnyy
Date: August 2nd, 2016
Written for: https://askubuntu.com/q/805515/295286
Tested on Ubuntu 16.04 LTS
import gi
gi.require_version('Gdk', '3.0')
gi.require_version('Gtk', '3.0')
from gi.repository import Gdk, Gtk
import time
import subprocess
import sys
import argparse
def run_cmd(cmdlist):
""" Reusable function for running shell commands"""
try:
stdout = subprocess.check_output(cmdlist)
except subprocess.CalledProcessError:
sys.exit(1)
else:
if stdout:
return stdout
def focus_windows_in_order(first, second, scr):
"""Raise two user-defined windows above others.
Takes two XID integers and screen object.
Window with first XID will have the focus"""
first_obj = None
second_obj = None
for window in scr.get_window_stack():
if window.get_xid() == first:
first_obj = window
if window.get_xid() == second:
second_obj = window
# When this function is called first_obj is alread
# raised. Therefore we must raise second one, and switch
# back to first
second_obj.focus(int(time.time()))
second_obj.get_update_area()
# time.sleep(0.25)
first_obj.focus(int(time.time()))
first_obj.get_update_area()
def get_user_window():
"""Select two windows via mouse. Returns integer value of window's id"""
window_id = None
while not window_id:
for line in run_cmd(['xwininfo', '-int']).decode().split('\n'):
if 'Window id:' in line:
window_id = line.split()[3]
return int(window_id)
def main():
""" Main function. This is where polling for window stack is done"""
# Parse command line arguments
arg_parser = argparse.ArgumentParser(
description="""Linker for two X11 windows.Allows raising """ +
"""two user selected windows together""")
arg_parser.add_argument(
'-q','--quiet', action='store_true',
help='Blocks GUI dialogs.',
required=False)
args = arg_parser.parse_args()
# Obtain list of two user windows
user_windows = [None, None]
if not args.quiet:
run_cmd(['zenity', '--info', '--text="select first window"'])
user_windows[0] = get_user_window()
if not args.quiet:
run_cmd(['zenity', '--info', '--text="select second window"'])
user_windows[1] = get_user_window()
if user_windows[0] == user_windows[1]:
run_cmd(
['zenity', '--error', '--text="Same window selected. Exiting"'])
sys.exit(1)
screen = Gdk.Screen.get_default()
flag = False
# begin watching for changes in window stack
while True:
window_stack = [window.get_xid()
for window in screen.get_window_stack()]
if user_windows[0] in window_stack and user_windows[1] in window_stack:
active_xid = screen.get_active_window().get_xid()
if active_xid not in user_windows:
flag = True
if flag and active_xid == user_windows[0]:
user_windows[0], user_windows[1], screen)
flag = False
elif flag and active_xid == user_windows[1]:
user_windows[1], user_windows[0], screen)
flag = False
else:
break
time.sleep(0.15)
if __name__ == "__main__":
main()
Notes:
- When running from command line, popup dialogs produce the following message:
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged. These can be ignored.
- Consult How can I edit/create new launcher items in Unity by hand? for creating a launcher or desktop shortcut for this script , if you desire to launch it with double-click
- In order to link this script to a keyboard shortcut for easy access, consult How to add keyboard shortcuts?
