I would like to increase the precision of column "modification" shown in Nautilus to include a time. This is under Unity.
I found this related question (concerning an older nautilus version), but I consider the answer (recompiling nautilus) overkill for my purposes.
Bruni
  • 11,099
There is a dconf setting which I think should control this behaviour, but it seems not to have any effect on Nautilus on my 16.04 Ubuntu (Unity desktop), it only affects file-choser windows like the "Open..." or "Save as..." dialogues of most applications.
You can get the current value of this setting using the command
gsettings get org.gtk.Settings.FileChooser date-format
The default is regular, the other option is with-time. You change the value with one of the two commands below.
gsettings set org.gtk.Settings.FileChooser date-format with-time
gsettings set org.gtk.Settings.FileChooser date-format regular
I am not sure whether it's a bug that this setting does not affect Nautilus or whether that is by design though. However, unfortunately I could not find anything closer to what you want.
Byte Commander
  • 110,243
