I just did the latest up date , when I turned on my Acer laptop this morning it started spazzing , it's asking for my login which I have no idea about but I know my password just not login , it says it after it first starts with lots of writing Can anybody help me out please ?
Your login password is the same as your user password.
  1. At the screen with a lot of writing where your boot has stopped, open a text-only virtual console by using the keyboard shortcut Ctrl+Alt+F3.
  2. At the login: prompt type your username and press Enter.
  3. At the Password: prompt type your user password and press Enter.
  4. After you have logged in in the console type:
    sudo service lightdm start # Ubuntu 14.10 and earlier
    or
    sudo systemctl start graphical.target # Ubuntu 15.04 and later
    and press Enter to bring up your default login screen and then login to your Ubuntu desktop environment as usual. If have a different desktop environment than the default Ubuntu Unity desktop environment, please comment so that I can change the command in Step 4.
After you have logged in to Ubuntu as usual, please check Where can I look up my update history? which tells you how to check your recent update history. Please provide information about what were the packages in your latest update, so that I can tell you how to undo the latest update.
karel
  • 122,292
  • 133
  • 301
  • 332
  • Enter you username in the login box.
  • If you do not know your username boot using a live CD (or if you are dual booting with Windows then use ext2fsd).
  • Open file browser and mount Ubuntu drive.
  • Go to home.
  • There must be a folder. The name of the folder is your username.
  • Reboot and login to Ubuntu.
  • Now open terminal, type in `sudo dpkg-reconfigure lights
  • Use arrow keys and select lightdm and press enter.
Note If you use Gnome replace lightdm with gdm3.
Ceda EI
  • 2,070
