after I installed Minecraft, I installed Java, and then I launched my game on 1.10.2 and I even tryed 1.10
My crash log:
---- Minecraft Crash Report ----
// Don't do that.
Time: 7/28/16 7:10 PM
Description: Initializing game
java.lang.ExceptionInInitializerError
    at bcx.ar(SourceFile:624)
    at bcx.an(SourceFile:432)
    at bcx.a(SourceFile:381)
    at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
    at org.lwjgl.opengl.LinuxDisplay.getAvailableDisplayModes(LinuxDisplay.java:951)
    at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:738)
    at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
    ... 4 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
    Minecraft Version: 1.10
    Operating System: Linux (amd64) version 4.4.0-31-generic
    Java Version: 1.8.0_91, Oracle Corporation
    Java VM Version: OpenJDK 64-Bit Server VM (mixed mode), Oracle Corporation
    Memory: 52439632 bytes (50 MB) / 152907776 bytes (145 MB) up to 1060372480 bytes (1011 MB)
    JVM Flags: 5 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
    IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
    Launched Version: 1.10
    LWJGL: 2.9.4
    OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
    GL Caps:
    Using VBOs: Yes
    Is Modded: Probably not. Jar signature remains and client brand is untouched.
    Type: Client (map_client.txt)
    Resource Packs:
    Current Language: ~~ERROR~~ NullPointerException: null
    Profiler Position: N/A (disabled)
    CPU: <unknown>
I've seen this issue before! :D
You aren't running a good graphics driver or window manager. The same thing happens when you use xiwi on a Chromebook, which is a Chromebook window, not capable of handling GL requests.
Looking across Ubuntu forms, I found this:
Steps:
From a terminal
1) sudo apt-get update
  • This will update your apt database to the most recent available packages.
2) sudo apt-get install build-essential
  • This installs the necessary development tools for building source code.
3) sudo apt-get install freeglut3-dev
  • This is the GL/GLUT package.
(https://ubuntuforums.org/showthread.php?t=345177)
I suggest you try this, and see what happens.
If you can, install the official drivers for your GPU. (The top answer for How to update OpenGL Driver on Ubuntu 14.04 LTS might work for you.)
Aly
  • 275
