115
We have 10 PC with some version of Ubuntu and only remote access. While doing some upgrades to custom software I did not notice that the line endings in some scripts were Windows version (CR+LF) and not the Unix version (LF). So now when I want to launch the script it gives an error:
bash: /usr/local/bin/portsee: /usr/bin/python^M: bad interpreter: No such file or directory
Is there a way to change all line endings in a script from terminal. The thing is that I can not install any new software to this group of PC-s.
Option 1: dos2unix
You can use the program dos2unix, which is specifically designed for this:
dos2unix file.txt
will replace all CR from all lines, in place operation.
To save the output in a different file:
dos2unix -n file.txt output.txt
You might need to install it first by:
sudo apt-get install dos2unix
Option 2: sed
Or you can use sed to replace all CR (\r) from line endings:
sed -i.bak 's/\r$//' file.txt
With option -i, the file will be edited in-place, and the original file will be backed up as file.txt.bak.
wjandrea
  • 14,504
heemayl
  • 93,925
The sed solution is not portable to all platforms. It didn't work for me on macOS unless I did brew install gsed and used gsed 's/\r$//'.
For a solution that works in most places without installing anything, I use
tr -d '\r'
To edit a file in-place, I produce the new data in a subshell before erasing and overwriting the original file:
echo "$(tr -d '\r' < file)" > file
