Disable touch-pad while typing doesn't work in the latest Lubuntu. So far I tried two solutions, non of them worked:
- Adding
syndaemon -d -tline to~/.config/lxsession/Lubuntu/autostartand restart. (source) - https://askubuntu.com/a/369366/496493
syndaemon -d -t line to ~/.config/lxsession/Lubuntu/autostart and restart. (source)Touchpad-Indicator does the job. It is not available from official Ubuntu repositories, so you need to add one manually. To ge the latest version, run the following in a terminal:
sudo add-apt-repository ppa:atareao/atareao
To install, run:
sudo apt-get update
sudo apt-get install touchpad-indicator
To disable touch-pad while typing, open the program and select the respective option from Preferences -> Actions.
Finally, don't forget to add the app to the startup list. You can do this within the same program, from Preferences -> General options tab. If that does not work, you might need to add it manually through your settings menu (in Lubuntu, it should be under Preferences -> Desktop Session Settings).
PS: some users mention a restart to make the program work.
For Lubuntu 19:
Click on "Start" -> Preferences -> LXQt Settings -> LXQt Configuration Center
Click on Session Settings
Select Autostart in the left panel
Click on Add
In the box that open enter any name like Touchpad disable.
In the Command type: xinput set-prop 13 "Device Enabled" 0
In my case the touchpad id is 13.
Find your device id in the terminal by entering the following in the terminal: xinput list
Reboot
I have used the synclient command:
synclient TouchPadOff=1
synclient TouchPadOff=0
TouchPadOff=1 to disable touch pad. TouchPadOff=0 to enable touch pad.
Then, I have added these two commands in hotkeys to make enable and disable tasks easy. It works fine.
