I turned on my Lenovo G510 and the WiFi wasn't working. I does not do anything after yesterday. I tried restarting the network, tried running rfkill unblock all, and I tried reinstalling the driver by following these instructions, but nothing is working.
Here is my generated WiFi-information file:
########## wireless info START ##########
Report from: 20 Jul 2016 21:15 EEST +0300
Booted last: 20 Jul 2016 21:11 EEST +0300
Script from: 08 Jul 2016 02:16 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 14.04.4 LTS
Release: 14.04
Codename: trusty
##### kernel ############################
Linux 3.19.0-65-generic #73~14.04.1-Ubuntu SMP Wed Jun 29 21:05:22 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
08:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
Subsystem: Lenovo Device [17aa:0611]
09:00.0 Ethernet controller [0200]: Qualcomm Atheros QCA8172 Fast Ethernet [1969:10a0] (rev 10)
Subsystem: Lenovo Device [17aa:3801]
Kernel driver in use: alx
##### lsusb #############################
Bus 004 Device 002: ID 8087:8000 Intel Corp.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 8087:8008 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 105b:e065 Foxconn International, Inc. BCM43142A0 Bluetooth module
Bus 001 Device 002: ID 0bda:5728 Realtek Semiconductor Corp.
##### PCMCIA card info ##################
##### rfkill ############################
##### lsmod #############################
cfg80211 532480 0
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0 Link encap:Ethernet HWaddr <MAC 'eth0' [IF1]>
inet addr:88.118.218.255 Bcast:88.118.223.255 Mask:255.255.240.0
inet6 addr: fe80::<IP6 'eth0' [IF1]>/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2292 errors:0 dropped:0 overruns:0 frame:0
TX packets:2272 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1596894 (1.5 MB) TX bytes:701771 (701.7 KB)
Interrupt:18
##### iwconfig ##########################
lo no wireless extensions.
eth0 no wireless extensions.
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 88.118.223.254 0.0.0.0 UG 0 0 0 eth0
88.118.208.0 0.0.0.0 255.255.240.0 U 1 0 0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
NetworkManager
Running:
root 831 1 0 21:11 ? 00:00:00 NetworkManager
##### NetworkManager info ###############
NetworkManager Tool
State: connected (global)
- Device: eth0 [Auto Ethernet] ------------------------------------------------
Type: Wired
Driver: alx
State: connected
Default: yes
HW Address: <MAC 'eth0' [IF1]>
Capabilities:
Carrier Detect: yes
Speed: 100 Mb/s
Wired Properties
Carrier: on
IPv4 Settings:
Address: 88.118.218.255
Prefix: 20 (255.255.240.0)
Gateway: 88.118.223.254
DNS: 212.59.8.8
DNS: 212.59.8.4
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/Komerservis]] (600 root)
[connection] id=Komerservis | type=802-11-wireless
[802-11-wireless] ssid=Komerservis | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/Teo-5EC56F-Greitasis]] (600 root)
[connection] id=Teo-5EC56F-Greitasis | type=802-11-wireless
[802-11-wireless] ssid=Teo-5EC56F-Greitasis | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
[[/etc/NetworkManager/system-connections/Thomson5D3064]] (600 root)
[connection] id=Thomson5D3064 | type=802-11-wireless
[802-11-wireless] ssid=Thomson5D3064 | mac-address=<MAC address>
[ipv4] method=auto
[ipv6] method=auto
##### iw reg get ########################
Region: Europe/Vilnius (based on set time zone)
country 00:
(2402 - 2472 @ 40), (3, 20)
(2457 - 2482 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(2474 - 2494 @ 20), (3, 20), NO-OFDM, PASSIVE-SCAN, NO-IBSS
(5170 - 5250 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(5735 - 5835 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
##### iwlist channels ###################
lo no frequency information.
eth0 no frequency information.
##### iwlist scan #######################
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
##### module infos ######################
[cfg80211]
filename: /lib/modules/3.19.0-65-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: 381EA511B7BC282E4E24C0E
depends:
intree: Y
vermagic: 3.19.0-65-generic SMP mod_unload modversions
signer: Magrathea: Glacier signing key
sig_key: 9B:61:23:81:C2:74:1F:1D:FD:FE:7D:9E:98:8A:BE:98:59:16:70:2A
sig_hashalgo: sha512
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist-bcm43.conf]
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
blacklist ideapad-laptop
blacklist ideapad-laptop exit
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x1969:0x10a0 (alx)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF1]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x14e4:0x4365 (wl)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC address>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[ 6.599529] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.600577] alx 0000:09:00.0 eth0: NIC Up: 100 Mbps Full
[ 6.601393] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
########## wireless info END ############
