I have this strange problem with conky. It doesn't show properly on the desktop:
It doesn't shown properly on the desktop.
I've tried everything from editing conky widget file to reinstalling conky and conky manager (v.2.4). Who knows how to fix it?
edwinksl
  • 24,109
I had the same issue lately with conky 1.10.1 on Ubuntu 16.04.1. I did not roll back conky. I fixed the issue by changing the line
own_window_type = 'desktop',
in my .conkyrc to
own_window_type = 'dock',
After all, my .conkyrc for Ubuntu 16.04.1 reads
os.execute("sleep 1")
conky.config = {
    background = true,
    double_buffer = true,
    alignment = 'top_right',
    border_width = 1,
    cpu_avg_samples = 2,
    default_color = 'white',
    default_outline_color = 'black',
    default_shade_color = 'black',
    draw_borders = false,
    draw_graph_borders = true,
    draw_outline = false,
    draw_shades = false,
    net_avg_samples = 2,
    no_buffers = true,
    out_to_console = false,
    out_to_stderr = false,
    extra_newline = false,
    own_window = true,
    own_window_transparent = false,
    own_window_argb_visual = true,
    own_window_argb_value = 64,
    own_window_colour = 'black',
    own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
    minimum_width = 170, minimum_height = 0,
    stippled_borders = 0,
    update_interval = 2.0,
    uppercase = false,
    use_spacer = 'none',
    show_graph_scale = false,
    show_graph_range = false,
    use_xft = true,
    xftalpha = 0.1,
    font = 'Droid Sans:size=11',
    color0 = 'white',
    color1 = 'EAEAEA',
    color2 = 'FFA300',
    color3 = 'grey'
conky.text = [[
${font AvantGardeLTMedium:bold:size=11}${color Tan1}System ${color slate grey}${hr 2}${font}
${color1}Computer name      ${alignr}${color}${nodename}
${color1}Kernel version     ${alignr}${color}${kernel}-${machine}
${color1}CPU frequency      ${alignr}${color}${freq_g}GHz
${color1}Load (average)     ${alignr}${color}${loadavg 1}
${color1}CPU temperature    ${alignr}${color}${acpitemp} degrees Celsius
${if_existing /sys/class/power_supply/BAT0/uevent}${font AvantGardeLTMedium:bold:size=11}${color Tan1}Laptop battery charge ${color slate grey}${hr 2}${font}
${color1}Battery charge     ${alignr}${color}${battery BAT0}${endif}
${if_existing /sys/class/power_supply/BAT1/uevent}${font AvantGardeLTMedium:bold:size=11}${color Tan1}Laptop battery charge ${color slate grey}${hr 2}${font}
${color1}Battery charge     ${alignr}${color}${battery BAT1}${endif}
${font AvantGardeLTMedium:bold:size=11}${color Tan1}Processors ${color slate grey}${hr 2}${font}
${color1}Kernel 1     ${color}${cpu cpu1}%  ${cpubar cpu1}
${font AvantGardeLTMedium:bold:size=11}${color Tan1}Memory (RAM) ${color slate grey}${hr 2}${font}
${color1}Memory free / total ${alignr}${color}${memeasyfree} / ${memmax}
${color1}Now in use   ${color}${memperc}%   ${membar}
${color1}Virtual memory (swap)  ${alignc}${color}${swap} / ${swapmax} ${color}${alignr}${swapperc} %
${font AvantGardeLTMedium:bold:size=11}${color Tan1}File system ${color slate grey}${hr 2}${font}
${color1}Root or /       ${alignc}${color}${fs_used /} / ${fs_size /} ${color}${alignr}${fs_free_perc /} %
${color}${fs_bar 5,300 /}
${color1}Home or /home   ${alignc}${color}${fs_used /home} / ${fs_size /home} ${color}${alignr}${fs_free_perc /home} %
${color}${fs_bar 5,300 /home}
${font AvantGardeLTMedium:bold:size=11}${color Tan1}Wireless network ${color slate grey}${hr 2}${font}
${if_existing /proc/net/route wlp3s0}${color1}Wireless access point ${alignr}${color}${wireless_essid wlp3s0}${endif}
${color1}Signal strength     ${alignr}${color}${wireless_link_qual_perc wlp3s0}   ${wireless_link_bar 10,100 wlp3s0}
${color1}Data traffic down / up   ${alignr}${color}${totaldown wlp3s0}  ${color1}/  ${color}${totalup wlp3s0}
My .conkyrc produces output as follows:
dzmanto
  • 371
It seems as though the 1.10 version of Conky is broken for now and some people are going back to the 1.9 version.
I can get just a few of them to work but, it took some time and tweaking just to get the few to work. So maybe this is a better option to just roll back then pulling out your hair trying to get them to work right.
  1. See which conky version is in installed on my 16.04 (Xenial) machine:
    $ conky -v | head -n 1 | cut -d" " -f 2
    1.10.1
  2. Remove this borked conky and purged it's configurations and leftover dependencies:
    sudo apt-get remove --purge conky-std && sudo apt-get autoremove
  3. I wanted conky version 1.9, which is not in the Ubuntu Xenial repos, so I snagged the package that shipped with Trusty:
    wget http://security.ubuntu.com/ubuntu/pool/universe/c/conky/conky-std_1.9.0-4_amd64.deb
  4. Once I had the .deb package downloaded, I installed it with gdebi rather dpkg so it would also install the necessary dependencies:
    sudo gdebi conky-std_1.9.0-4_amd64.deb
  5. Check the version that is installed:
    1.9.0
  6. Pin the package at the 1.9.0 version so future package updates don't revert us back up to the bad version:
    sudo apt-mark hold conky-std
This is what I have working for now.
karel
  • 122,292
  • 133
  • 301
  • 332
