I used apt-get for almost installing every application i needed, but after installing a new Ubuntu version (16.04) I am no longer able to use that command. every time I use it it tells the packages I am installing has unmet dependencies, it happened when I tried to install Java, LibreOffice, flash and even aptitude.
As an example this is the output that I get when I try to install LibreOffice
sudo apt-get install libreoffice
Reading package lists... Done
Building dependency tree
libreoffice : Depends: libreoffice-base but it is not going to be installed
Depends: libreoffice-calc but it is not going to be installed
Depends: libreoffice-core (= 1:5.1.4-0ubuntu1) but it is not going to be installed
Depends: libreoffice-draw but it is not going to be installed
Depends: libreoffice-impress but it is not going to be installed
Depends: libreoffice-math but it is not going to be installed
Depends: libreoffice-report-builder-bin but it is not going to be installed
Depends: libreoffice-writer but it is not going to be installed
Depends: libreoffice-avmedia-backend-gstreamer but it is not going to be installed
Depends: fonts-dejavu but it is not going to be installed
Depends: python3-uno (>= 4.4.0~beta2) but it is not going to be installed
Recommends: libreoffice-gnome but it is not going to be installed or
libreoffice-kde but it is not going to be installed
The output of "dir /etc/apt/sources.list.d"
libreoffice-ubuntu-libreoffice-4-4-xenial.list
openjdk-r-ubuntu-ppa-xenial.list
openjdk-r-ubuntu-ppa-xenial.list.save
webupd8team-ubuntu-java-xenial.list
webupd8team-ubuntu-java-xenial.list.save
the output of cat /etc/apt/sources.list
# deb cdrom:[Ubuntu 16.04 LTS _Xenial Xerus_ - Release amd64 (20160420.1)]/ xenial main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://archive.ubuntu.com/ubuntu xenial restricted multiverse
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu xenial-updates restricted multiverse
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://archive.ubuntu.com/ubuntu xenial universe
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial universe
deb http://archive.ubuntu.com/ubuntu xenial-updates universe
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial multiverse
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu xenial-backports restricted universe multiverse
# deb-src http://ae.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu xenial partner
# deb-src http://archive.canonical.com/ubuntu xenial partner
deb http://archive.ubuntu.com/ubuntu xenial-security restricted multiverse
# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
deb http://archive.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
deb http://security.ubuntu.com/ubuntu lucid-security main multiverse
deb http://ftp.debian.org/debian wheezy-backports main
deb http://ftp.debian.org/debian jessie-backports main
the output of sudo apt-get update
Hit:1 http://archive.ubuntu.com/ubuntu xenial InRelease
Ign:2 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial InRelease
Hit:3 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Ign:4 http://security.ubuntu.com/ubuntu lucid-security InRelease
Hit:5 http://ppa.launchpad.net/openjdk-r/ppa/ubuntu xenial InRelease
Hit:6 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Hit:7 http://ppa.launchpad.net/webupd8team/java/ubuntu xenial InRelease
Ign:8 http://security.ubuntu.com/ubuntu lucid-security Release
Hit:9 http://archive.ubuntu.com/ubuntu xenial-security InRelease
Ign:10 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial Release
Ign:11 http://security.ubuntu.com/ubuntu lucid-security/main amd64 Packages.diff/Index
Ign:12 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main amd64 Packages
Ign:13 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main i386 Packages
Ign:14 http://security.ubuntu.com/ubuntu lucid-security/main i386 Packages.diff/Index
Ign:15 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main all Packages
Ign:16 http://security.ubuntu.com/ubuntu lucid-security/main all Packages
Ign:17 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main Translation-en_US
Ign:18 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main Translation-en
Ign:19 http://security.ubuntu.com/ubuntu lucid-security/main Translation-en_US
Ign:20 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:21 http://security.ubuntu.com/ubuntu lucid-security/main Translation-en
Ign:22 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main DEP-11 64x64 Icons
Ign:23 http://security.ubuntu.com/ubuntu lucid-security/main amd64 DEP-11 Metadata
Ign:24 http://security.ubuntu.com/ubuntu lucid-security/main DEP-11 64x64 Icons
Ign:25 http://security.ubuntu.com/ubuntu lucid-security/multiverse amd64 Packages.diff/Index
Ign:26 http://security.ubuntu.com/ubuntu lucid-security/multiverse i386 Packages.diff/Index
Ign:27 http://security.ubuntu.com/ubuntu lucid-security/multiverse all Packages
Ign:28 http://security.ubuntu.com/ubuntu lucid-security/multiverse Translation-en_US
Ign:29 http://security.ubuntu.com/ubuntu lucid-security/multiverse Translation-en
Ign:30 http://security.ubuntu.com/ubuntu lucid-security/multiverse amd64 DEP-11 Metadata
Ign:31 http://security.ubuntu.com/ubuntu lucid-security/multiverse DEP-11 64x64 Icons
Ign:32 http://security.ubuntu.com/ubuntu lucid-security/main amd64 Packages
Ign:33 http://security.ubuntu.com/ubuntu lucid-security/main i386 Packages
Ign:34 http://security.ubuntu.com/ubuntu lucid-security/multiverse amd64 Packages
Ign:35 http://security.ubuntu.com/ubuntu lucid-security/multiverse i386 Packages
Get:36 http://ftp.debian.org/debian wheezy-backports InRelease [163 kB]
Err:12 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main amd64 Packages
404 Not Found
Err:13 http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial/main i386 Packages
404 Not Found
Ign:36 http://ftp.debian.org/debian wheezy-backports InRelease
Get:37 http://ftp.debian.org/debian jessie-backports InRelease [166 kB]
Ign:37 http://ftp.debian.org/debian jessie-backports InRelease
Err:32 http://security.ubuntu.com/ubuntu lucid-security/main amd64 Packages
404 Not Found [IP: 91.189.88.161 80]
Err:33 http://security.ubuntu.com/ubuntu lucid-security/main i386 Packages
Err:34 http://security.ubuntu.com/ubuntu lucid-security/multiverse amd64 Packages
Err:35 http://security.ubuntu.com/ubuntu lucid-security/multiverse i386 Packages
Fetched 329 kB in 18s (18.0 kB/s)
W: The repository 'http://security.ubuntu.com/ubuntu lucid-security Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu xenial Release' does not have a Release file.
W: GPG error: http://ftp.debian.org/debian wheezy-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 7638D0442B90D010
W: The repository 'http://ftp.debian.org/debian wheezy-backports InRelease' is not signed.
W: There is no public key available for the following key IDs:
W: GPG error: http://ftp.debian.org/debian jessie-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 7638D0442B90D010
W: The repository 'http://ftp.debian.org/debian jessie-backports InRelease' is not signed.
E: Failed to fetch http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu/dists/xenial/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://ppa.launchpad.net/libreoffice/libreoffice-4-4/ubuntu/dists/xenial/main/binary-i386/Packages 404 Not Found
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/lucid-security/main/binary-amd64/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/lucid-security/main/binary-i386/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/lucid-security/multiverse/binary-amd64/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/lucid-security/multiverse/binary-i386/Packages 404 Not Found [IP: 91.189.88.161 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
