I downloaded Android Studio, and untared it in /usr/local as I read I should to avoid it eating /home space. Then I added the path to the /bin folder to the PATH variable, but I still can't execute it without going to /usr/local/android-studio/bin and executing ./studio.sh from the shell.
Is there any way to make it show up in "Search your computer and online sources" like other programs I downloaded using apt-get install?
You want to create a .desktop file.
This can be done manually as described here.
Alternatively, it should be enough for most applications to run them and then right-click on their launcher icon. The appearing context menu should offer an option Lock to launcher or Add to Dash or similar.
Chose that and Ubuntu will try to automatically create an appropriate .desktop file that will make your application show up in the Dash. You may unlock it from the launcher again if you want to, it will remain in the Dash anyway.
Byte Commander
  • 110,243
This solves the first half of your question, but I'm not sure about the second half, or if the second half is simply there to help to solve the first half.
Try installing the run script to /usr/local/bin, like this:
cd to directory where Android Studio is installed
sudo install studio.sh /usr/local/bin/studio
Then you can run it with studio from any directory.
P Smith
  • 569
Have you given the file the permissions to execute?
sudo chmod +x studio.sh
or maybe you can try:
sh studio.sh
I have installed Android Studio last year and it all went fine, if this doesn't solve your problem, comment that I'll try to see other solutions :)
