I am looking to copy the keyboard shortcuts file to another PC to avoid re-binding the keys again. I am using Ubuntu Gnome 16.04.
In Xubuntu there is a simple location with the keyboard shortcuts in a file in ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml. You can copy and paste this file to another computer, and you have all your familiar keyboard shortcuts. Is there an equivalent file in Ubuntu Gnome?
Rockishi
  • 623
Also here.
Save custom keyboard shortcuts
You can save/backup/export custom shortcuts/keybindings using just dconf and sed
Export
dconf dump / | sed -n '/\[org.gnome.settings-daemon.plugins.media-keys/,/^$/p' > custom-shortcuts.conf # Export
The difference with the usual answer is that this will hold on the file the path to the dconf settings, making it easier to import, just dconf load / < file.
Import
dconf load / < custom-shortcuts.conf # Import
Notes
  • Based on Ciro's answer (also here)
  • Only for the added custom shortcuts
  • Note that dconf only dumps non-default values
  • To backup, you may want to use custom-shortcuts-$(date -I).conf
  • Test if it works by resetting to defaults before the import
    gsettings reset-recursively org.gnome.settings-daemon.plugins.media-keys
Pablo Bianchi
  • 17,371
GNOME stores its settings in the dconf binary database which can also be viewed or changed with the gsettings command line tool or the dconf-editor app.
The database is stored in ~/.config/dconf/user . You can copy that file to another computer to copy all of your GNOME settings including your keyboard shortcuts. That folder is hidden by default. Use the keyboard shortcut Ctrl+H to view hidden folders.
Other apps store their settings in other parts of the ~/.config folder or directory.
Jeremy Bicha
  • 8,294
