My Front Headphone port has stopped working on its own recently as in no sound is coming from them. It was working fine till last week after I applied some fix I found on Google. I am sorry but I don't remember what exactly I did but it involved me having to run alsamixer on every reboot to fix the headphone volume.
And now even after I fix the volume using alsamixer, there is no sound coming from the front ports. Back ports are working fine though. I am using Ubuntu 16.04.
Any help? I am very much confused on how to troubleshoot or from where to start?
user.dz
  • 49,176
I tried to reset alsactl using this command and it worked. There's no need to reinstall anything.
sudo alsactl restore
Note: If you see Device or resource busy, login to a tty(Ctrl+Alt+F6 or Ctrl+Alt+F7) and run the command at there.
Edit:
It seems that I mistakenly assumed that the sound was coming from my headphone. My headphone still didn't work.
This time I tried this:
sudo apt install alsa-tools-gui
hdajackretask
In the new window, select the correct codec at the top. Click "show unconnected pins. Click "override" on each unconnected pins and choose "Headphone" for every pins that have this choice(don't change connected pins). Click "Install boot override" and then reboot. Now it worked.
LouYu
  • 131
This worked-out for me.
In the ‘Terminal’ write alsamixer
In 'AlsaMixer' select Headphone using the side-arrows keys in Keyboard.
Now press m in Keyboard (mouse dose not work here) to Unmute the Headphone. ( When the Headphone is mute you can see in the column it shows MM, and after you unmute the Headphone, it will show OO) Press up-down arrow keys to control sound in your Headphone. Now to save the configuration run this command:
sudo alsactl store
So the next time you open your pc, it will boot-up with that config.
Debajyoti
  • 960
user.dz
  • 49,176
