Where can I set CLI flags for Google Chrome on Unity?
Look in /opt/google/chrome/google-chrome.desktop or /usr/share/applications/google-chrome.desktop for the following line:
Exec=/opt/google/chrome/google-chrome %U
Add the flag you need in there, save it, then run Chrome again and pin it to your launcher, that should do the trick.
    - 135
    - 73,717
For xubuntu/xfce4, though it might work similarly elsewhere:
cp /usr/share/applications/google-chrome.desktop ~/.local/share/applications/google-chrome.desktop
and modify the three Exec= lines in ~/.local/share/applications/google-chrome.desktop to include the arguments you want.  Because it has the same filename, xfce4-whiskermenu will pick up only your modified google-chrome.desktop.
If Chrome is your default browser, another application opening a URL will still cause Chrome to launch without your arguments.  To fix this, create a new file ~/bin/google-chrome with these contents:
/usr/bin/google-chrome YOUR_EXTRA_ARGS "$@"
and chmod +x ~/bin/google-chrome.  Then, in Preferred Applications, set your Web Browser to Other... and enter:
/home/YOUR_USERNAME/bin/google-chrome "%s"
Also, to avoid having to change the arguments in four places in the future, you can point the Exec= lines in google-chrome.desktop to your /home/YOUR_USERNAME/bin/google-chrome.
    - 200
A way is to set flags in the environment variable CHROMIUM_USER_FLAGS:
export CHROMIUM_USER_FLAGS="insert_content_here"
    - 3,175
    - 31
I'm running Xubuntu and I was trying to figure this one out as well. I tried the solution to edit the .desktop file. I haven't updated, but I have the same concern as you (will it get overwritten). I tried a different option where I added an alias to my .bashrc file.
alias chromium-browser="/usr/bin/chromium-browser [FLAGS]"
    - 21
For chromium, you can create a script in /etc/chromium-browser/customizations
For instance i have a script with one line
CHROMIUM_FLAGS="${CHROMIUM_FLAGS} --enable_hidpi=1 --process-per-site"
I imagine chrome has something similar.
    - 298
For Chromium, the method suggested by @errr is correct, however, it is deprecated as of Chromium 52 (or earlier):
┌ alex [~]
└──> export CHROMIUM_USER_FLAGS="--version"
┌ alex [~]
└──> chromium-browser
Using PPAPI flash.
WARNING: $CHROMIUM_USER_FLAGS is deprecated. Instead, update   CHROMIUM_FLAGS in ~/.chromium-browser.init or place configuration for all sers in /etc/chromium-browser/customizations/ .
WARNING: Ignoring system flags because $CHROMIUM_USER_FLAGS is set.
CHROMIUM_FLAGS= --ppapi-flash-path=/usr/lib/adobe-flashplugin/libpepflashplayer.so --ppapi-flash-version=
CHROMIUM_USER_FLAGS=--version
Chromium 52.0.2743.116 Built on Ubuntu , running on Ubuntu 16.04
As you can see, the solution is quite obvious however.
┌ alex [~]
└──> echo "CHROMIUM_FLAGS=\"--version\"" >> ~/.chromium-browser.init
chromium-browser
┌ alex [~]
└──> chromium
Using PPAPI flash.
These changes will persist through upgrades, making it superior to solutions updating system files.
However, for Google Chrome, I have not found a single way other than modifying desktop files or writing custom launchers.
    - 166
- Edit /usr/share/applications/google-chrome.desktop
- Add the desired flags to the Execline
- Run sudo chattr +a /usr/share/applications/google-chrome.desktopto prevent your change from being overwritten on update.
    - 135
First, open up a terminal. Then type in google-chrome-(release-type) -(flag)
Replace (release-type) with the release of google chrome you are using (stable,unstable,ect.) and (flag) with the flag that you want to run Google Chrome with.
To have the flags run when you click on the Google Chrome Unity icon in the launcher:
- first install Unity Launcher Editor.
- Open up a terminal window and type sudo apt-get install bzr.
- When it is has finished installing, type bzr branch lp:unity-launcher-editor.
- Next, launch Unity Launcher Editor by typing ~/unity-launcher-editor/unitylaunchereditor/main.py.
- Now, click on the Google Chrome icon, and add the flag you want to run in the Command box.
    - 553
    - 5,035
