These were my steps to install node on Ubuntu 16.04:
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejs
sudo apt-get install -y npm
which are the official instructions:
https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions
After doing this, running nodejs --version returns v4.2.6.
As I used setup_6.x I was assuming a version beginning with 6 would be installed?
I thought perhaps setup_6.x should be setup_6.2.1, but that page returns a 404, see:
https://deb.nodesource.com/setup_6.x (there is a page there)
https://deb.nodesource.com/setup_6.2.1 (returns a 404)
How do I install the latest stable version of node on Ubuntu 16.04?
Edit:
These are results after running sudo apt-get install -y nodejs:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
gyp libboost-python1.58.0 libjs-inherits libjs-node-uuid libjs-underscore
libssl-dev libssl-doc libuv1-dev linux-headers-4.4.0-18
linux-headers-4.4.0-18-generic linux-headers-4.4.0-21
linux-headers-4.4.0-21-generic linux-image-4.4.0-18-generic
linux-image-4.4.0-21-generic linux-image-extra-4.4.0-18-generic
linux-image-extra-4.4.0-21-generic linux-signed-image-4.4.0-18-generic
linux-signed-image-4.4.0-21-generic python-configobj python-pycurl
python-pyexiv2 python-pyexiv2-doc
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
nodejs
0 to upgrade, 1 to newly install, 0 to remove and 0 not to upgrade.
Need to get 0 B/3,162 kB of archives.
After this operation, 13.2 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 329473 files and directories currently installed.)
Preparing to unpack .../nodejs_4.2.6~dfsg-1ubuntu4_amd64.deb ...
Unpacking nodejs (4.2.6~dfsg-1ubuntu4) ...
Processing triggers for doc-base (0.10.7) ...
Processing 1 added doc-base file...
Registering documents with scrollkeeper...
Processing triggers for man-db (2.7.5-1) ...
Setting up nodejs (4.2.6~dfsg-1ubuntu4) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
Edit:
Results of apt-cache policy nodejs:
nodejs:
Installed: 4.2.6~dfsg-1ubuntu4
Candidate: 4.2.6~dfsg-1ubuntu4
Version table:
*** 4.2.6~dfsg-1ubuntu4 500
500 http://au.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
100 /var/lib/dpkg/status
