When i tried to install npm install -g react-native-cli
then i faced an error like below :
npm WARN engine react-native-cli@1.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.25","npm":"1.4.21"})
npm ERR! tar.unpack untar error /home/putuguna/.npm/react-native-cli/1.0.0/package.tgz
npm ERR! Error: EACCES, mkdir '/usr/local/lib/node_modules'
npm ERR! { [Error: EACCES, mkdir '/usr/local/lib/node_modules']
npm ERR! errno: 3,
npm ERR! code: 'EACCES',
npm ERR! path: '/usr/local/lib/node_modules',
npm ERR! fstream_type: 'Directory',
npm ERR! fstream_path: '/usr/local/lib/node_modules/react-native-cli',
npm ERR! fstream_class: 'DirWriter',
npm ERR! fstream_stack:
npm ERR! [ '/usr/lib/nodejs/fstream/lib/writer.js:171:23',
npm ERR! '/usr/lib/nodejs/mkdirp/index.js:46:53',
npm ERR! 'Object.oncomplete (fs.js:107:15)' ] }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! System Linux 4.2.0-16-generic
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "react-native-cli"
npm ERR! cwd /home/putuguna
npm ERR! node -v v0.10.25
npm ERR! npm -v 1.4.21
npm ERR! path /usr/local/lib/node_modules
npm ERR! fstream_path /usr/local/lib/node_modules/react-native-cli
npm ERR! fstream_type Directory
npm ERR! fstream_class DirWriter
npm ERR! code EACCES
npm ERR! errno 3
npm ERR! stack Error: EACCES, mkdir '/usr/local/lib/node_modules'
npm ERR! fstream_stack /usr/lib/nodejs/fstream/lib/writer.js:171:23
npm ERR! fstream_stack /usr/lib/nodejs/mkdirp/index.js:46:53
npm ERR! fstream_stack Object.oncomplete (fs.js:107:15)
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /home/putuguna/npm-debug.log
npm ERR! not ok code 0
Could you help me for solve my problem
Update :
One thing that i know, i should update my node js version. I have done, by this way :
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
But the error above appears again. please help
