I have an Ubuntu 14.04 server with btrfs (SSD drive) as /, and I have a bind of another drive (SATA) to /home. The SSD drive has reported that is out of free space, so I read this, applied some of the suggestions, and removed some files. This is what btrfs now reports:
# btrfs fi show /
Label: system  uuid: 2322b989-2110-494b-96b0-40aaee2f3998
    Total devices 1 FS bytes used 6.20GiB
    devid    1 size 26.08GiB used 22.52GiB path /dev/sdc1
# btrfs fi df /
Data, single: total=21.76GiB, used=5.69GiB
System, single: total=4.00MiB, used=16.00KiB
Metadata, single: total=776.00MiB, used=522.03MiB
# btrfs subvolume list /
ID 257 gen 2090434 top level 5 path @
ID 258 gen 1048023 top level 5 path @home
df -h
/dev/sdc1        27G  6.3G   20G  25% /
It is safe to remove @home as it is actually a bind to another drive? But before that, I just want to be sure I'm reading the above numbers correctly... The drive is using around 6GB out of 26G, right?
UPDATE
This is my fstab (relevant parts):
UUID=2322b989-2110-494b-96b0-40aaee2f3998   /   btrfs   noatime,nodiratime,notreelog,ssd,discard,subvol=@   0   1
UUID=858a4a9d-a901-47c7-89d2-0ef97ef6f23f   /mnt/ext ext4  defaults,acl,user_xattr,noatime,nodiratime 0  1
/mnt/ext/home /home   none bind
lepe
  • 1,506
It looks like you can safely remove the @home subvolume. It is not mounted anywhere on boot.
I recommend to check if there is anything important there left. You can unmount the HDD for that and see what is in /home.
Pilot6
  • 92,041
