$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=a168d1ac-4e13-4643-976d-6e47ea1732b1 /boot ext2 defaults 0 1
/dev/mapper/sda4_crypt / btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@ 0 2
/dev/mapper/sda4_crypt /tmp btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@tmp 0 2
/dev/mapper/sda4_crypt /run btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@run 0 2
/dev/mapper/sda4_crypt /var/crash btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@var-crash 0 2
/dev/mapper/sda4_crypt /var/tmp btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@var-tmp 0 2
/dev/mapper/sda4_crypt /var/log btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@var-log 0 2
/dev/mapper/sda4_crypt /var/spool btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@var-spool 0 2
/dev/mapper/sda5_crypt /home btrfs defaults,autodefrag,compress=lzo,inode_cache,space_cache,subvol=@home 0 3
/dev/mapper/750er /media/750er ext4 defaults 0 4
/dev/mapper/cswap none swap defaults 0 5
➜ ~ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/sda4_crypt 38G 12G 13M 100% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
udev 2,0G 4,0K 2,0G 1% /dev
tmpfs 396M 1,3M 394M 1% /run
none 5,0M 0 5,0M 0% /run/lock
none 2,0G 208K 2,0G 1% /run/shm
none 100M 36K 100M 1% /run/user
/dev/mapper/sda4_crypt 38G 12G 13M 100% /tmp
/dev/sda2 231M 44M 175M 21% /boot
/dev/mapper/sda4_crypt 38G 12G 13M 100% /var/crash
/dev/mapper/sda4_crypt 38G 12G 13M 100% /var/tmp
/dev/mapper/sda4_crypt 38G 12G 13M 100% /var/log
/dev/mapper/sda4_crypt 38G 12G 13M 100% /var/spool
/dev/mapper/sda5_crypt 3,7T 2,4T 1,2T 67% /home
/dev/mapper/750er 688G 276G 377G 43% /media/750er
/dev/mapper/2tb 1,8T 1,7T 141G 93% /media/2tb
➜ ~ sudo btrfs fi df /
Data, single: total=9.47GiB, used=9.46GiB
System, DUP: total=8.00MiB, used=16.00KiB
System, single: total=4.00MiB, used=0.00
Metadata, DUP: total=13.88GiB, used=1.13GiB
Metadata, single: total=8.00MiB, used=0.00
It's a 40GB partition with quite some snapshots on it. But it's compressed so I think the 9,46GB/40GB is accurate. But my Ubuntu fails because it says it has no disk space. I had apt-errors, cant install programs and my mysql server failed to start because of it.
And I know about not to rely on df I just included it for completeness.
I think Ubuntu uses df which is known to report wrongly with Btrfs internally and fails for that reason. That would make sense for APT when it does checks for space. But it actually fails to write to disk.
$ sudo time dd if=/dev/zero of=large bs=2G count=1
dd: error writing ‘large’: No space left on device
0+1 records in
0+0 records out
11747328 bytes (12 MB) copied, 1,29706 s, 9,1 MB/s
Command exited with non-zero status 1
0.00user 1.40system 0:01.44elapsed 97%CPU (0avgtext+0avgdata 2098028maxresident)k
160inputs+23104outputs (0major+383008minor)pagefaults 0swaps
