I suspect it might not be possible to do this yet.
From going through libertine-container-manager --help I think the command should be
libertine-container-manager configure -a "ppa:ubuntuhandbook1/corebird" -i vivid
The equivalent of apt-get update is just
libertine-container-manager update -i vivid
You'll find this and more with libertine-container-manager --help.
However when I execute the first command I get the following error:
phablet@ubuntu-phablet:~$ libertine-container-manager configure -a "ppa:ubuntuhandbook1/corebird" -i vivid
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 321, in get_ppa_info
ret = get_ppa_info_from_lp(user, ppa)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 91, in get_ppa_info_from_lp
return get_info_from_lp(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 87, in get_info_from_lp
return _get_https_content_py3(lp_url)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 101, in _get_https_content_py3
lp_page = urllib.request.urlopen(request, cafile=LAUNCHPAD_PPA_CERT)
File "/usr/lib/python3.4/urllib/request.py", line 151, in urlopen
capath=capath)
File "/usr/lib/python3.4/ssl.py", line 437, in create_default_context
context.load_verify_locations(cafile, capath, cadata)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/bin/add-apt-repository", line 119, in <module>
shortcut = shortcut_handler(line)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 837, in shortcut_handler
ret = factory(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 382, in shortcut_handler
return PPAShortcutHandler(shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 346, in __init__
info = get_ppa_info(self.shortcut)
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 333, in get_ppa_info
_get_suggested_ppa_message(user, ppa))
File "/usr/lib/python3/dist-packages/softwareproperties/ppa.py", line 292, in _get_suggested_ppa_message
lp_user = get_info_from_lp(LAUNCHPAD_USER_API % user)
capath=capath)
