I have created a libertine container and successfully installed x11 apps.
I have also installed git. How can I access this, or other command line applications from the terminal?
muru
  • 207,228
Jack
  • 532
I found a similar question which provides the answer How do I run a command using libertine-container-manager exec
libertine-container-manager exec -c "tool"
This works for apps installed in the default puritine container. If you want to use something you have installed in a container you created yourself you need to specify that:
libertine-container-manager exec -c "tool" -i your_container
Jack
  • 532
