I am using the latest Xubuntu x64 version as of this posting.. It's installed in dual boot with Windows 10.. the KB Backlight is working when I boot on Windows and from the bios.. The moment It enters the Xubuntu Startup screen the KB Backlight turns off and doesn't turn on.. Thanks in advance for the help..
Output of: ls /sys/class/leds/
input3::capslock
input3::numlock
input3::scrolllock
phy0-led
im.earl
To enable the backlight:
echo 2 | sudo tee /sys/class/leds/toshiba::kbd_backlight/brightness
The 2 at echo 2 | can be changed to a value between 0 - 3, with 3 being the brightest.
To disable the backlight, enter:
echo 0 | sudo tee /sys/class/leds/toshiba::kbd_backlight/brightness
reference this answer but changing asus to toshiba .
Updated
some people whom report this issue say disabling acpi solve the problem to disable acpi:
  1. open terminal
  2. edit /etc/default/grub
  3. append acpi = off to GRUB_CMDLINE_LINUX_DEFAULT
  4. update-grub
  5. if not working do these steps again and delete acpi = off
if none of these solution work may it's this bug
try with Fn+Z it worked in my toshiba
Reference found here https://forum.manjaro.org/t/toshiba-backlight-keyboard/25235
ejaenv
  • 101
